Author Topic: McLeods new Muscle Car 5 Transmission  (Read 7211 times)
Offline jvike
  • Pro-Touring Cuda
« on: November 08, 2014 - 07:52:52 AM »
Did y'all catch this? McLeod launched a new 5 speed transmission to fit without cuting the tunel. They showed it at SEMA in a 1970 Cuda with 1000++hp GenII Hemi. It sells for $2795
Link to trans --> http://www.mcleodracing.com/index.php/driveline/mcleod-muscle-car-5-transmission.html
Build thread on Cuda --> http://www.pro-touring.com/threads/103221-Mcleod-s-70-cuda-project
Hot Rod' --> http://www.hotrod.com/cars/featured/1411-mcleod-racing-1970-hemi-plymouth-barracuda/
Dragzine --> http://www.dragzine.com/news/transmission-upgrades-the-mcleod-muscle-car-5-manual-transmission/
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
Re: McLeods new Muscle Car 5 Transmission
« Reply #1 on: November 08, 2014 - 08:04:40 AM »
That's pretty cool!!
E-Body Products
www.ebodyproducts.com
606-481-9014
Offline anlauto
« Reply #2 on: November 08, 2014 - 08:52:32 AM »
Well that would be good :2thumbs:
Offline twalker
« Reply #3 on: November 08, 2014 - 08:56:42 AM »
Excellent, competition is needed
Offline anlauto
« Reply #4 on: November 08, 2014 - 09:02:28 AM »
Correct me if I'm wrong..I didn't read all the articles, but wouldn't you have to cut the floor on a Cuda for a center mounted shifter, and a console would be out of the question ?
Offline roadman5312
« Reply #5 on: November 08, 2014 - 09:04:09 AM »
                                                             :iagree: That was my first thought.
Offline Travis72
« Reply #6 on: November 08, 2014 - 12:13:30 PM »
Yeah more competition is better.
However the Cuda they used for the demo has a full custom chassis and custom floorboards.  So not exactly the best demo model to prove it fits!
Travis
72 Cuda
Offline anlauto
« Reply #7 on: November 08, 2014 - 01:06:16 PM »
Exactly :sly:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: November 08, 2014 - 01:18:11 PM »
Dang it, got me excited about an easier swap to 5speed.
One other crazy item of note, he built a 1000hp blown hemi motor but only put a transmission that can handle up to 500ft/lbs of torque. Guess at some point he might want to rethink that.
It looks good to me all the way up until I saw that high rise shifter area.
 :villagers:
Offline 73EStroker
« Reply #9 on: November 08, 2014 - 02:11:53 PM »
 :villagers:
Its like a Ferrari engine -- all HP and no torque  :roflsmiley:
Barry (Salmon Arm)
Offline 73EStroker
« Reply #10 on: November 08, 2014 - 02:15:07 PM »
I also call bullship on the height of the box. My Passon A855 is way lower and fits with about an inch above for clearance. That looks like the Legend unit out of the US south. I also think that exposed shifter rod will bring in lots of grime over time. But those are small issues if it mechanically fits where the A833 came out but Quick time bellhousing (cause that bolt pattern dont look Dodgy to me), special clutch stuff, driveshaft looks like it needs to be longer. Ka-ching ka-ching suddenly you are up to about $4500 hmmmmmmm.
« Last Edit: November 08, 2014 - 02:24:33 PM by 73EStroker »
Barry (Salmon Arm)
Offline anlauto
« Reply #11 on: November 08, 2014 - 02:42:19 PM »
I wonder if this one on display is for a Chevy or something and they have a different one for Mopars ? :dunno:
Offline ragtopdodge
« Reply #12 on: November 08, 2014 - 03:22:23 PM »
"2.95 1st gear and a .63 5th gear"
Not a fan of that gear spread.  Talk about granny gear and super tall 5th.  No thanks.
And no thanks to only 500 ft-lb rating.  Sounds like a TKO 500.
Passon A855 only trans worth its salt to retrofit in our cars.  Too bad you need a 1.5 year wait to get one.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #13 on: November 09, 2014 - 11:49:26 AM »
No problem with the spread , Mopars have a long flat torque curve anyway , not much different than the 833 OD but with 5 gears between not 4 !
the upper shift rail is never going to fit the stock floor & 500 ft lbs rated  what is that good for . definatly need a different belhousing flywheel & clutch might work depending on the spline they chose what about clutch linkage ?
 I still prefer Jamies 855 personally !
Offline bigblue73
« Reply #14 on: November 10, 2014 - 12:41:36 PM »
Do you see the location of the shifter with respect to the rest of the transmission?  It's a tower that can be milled, drilled, tapped, bracket attached to and the shaft extended thru to fit the E-Bodies.  Red Roberts has his hand in this and it will be first class.  It sure looks nice and compact.
