Author Topic: speaker rear defrost?  (Read 19828 times)
Offline sleepie74
« on: November 08, 2014 - 02:07:48 PM »
hi, i posted in parts wanted and so far nothing, thought i might take a diff approch here.  I have the blower-speaker adapter, but it lacks the bottom side that has the two ovals cut into it --to mount the speaker and the blower motor.. i was wondering if someone that had this { out of the car of course}  could trace theirs and send me the tracing --so i might have one made,, just a thought,, thanks alot----pat
Offline Finoke
Re: speaker rear defrost?
« Reply #1 on: November 08, 2014 - 11:11:39 PM »
I have this that came in a parts lot that I just acquired. Is this what your talking about or can you at least tell me what this is that I have?
Tom
Offline sleepie74
« Reply #2 on: November 09, 2014 - 09:38:44 AM »
tom, that is exactly what i have,, there is another part to that, that has two 6x9 holes in it that the speaker and blower mount to. then the two go together. you seem to be missing the same part. this is used to have two rear speakers and the defrost. from what i hear a rare item.. if anyone has the other part, that would be great? but i think we may have to have one made from a tracing of the other part.. if i get a tracing i will let you know, thanks for response----pat
Offline miketyler
    • www.miketyler.net
« Reply #3 on: November 09, 2014 - 10:04:07 AM »
I installed one of these in my 72 Cuda when I was on the trek of installing every OEM convenience option there was. You are right, it was hard to find along with the wiring, switch and switch panel. Let me see if I have some pics of the unit for you.
EDIT: Found pics
« Last Edit: November 09, 2014 - 10:09:34 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Finoke
« Reply #4 on: November 09, 2014 - 11:55:52 AM »
Thanks for the education Guys. Very interesting. I looked through the rest of the parts that I have and didn't find what you need.  :faint:
I did find a switch facia and a nos defrost switch with switch wiring harness. I'm guessing cuda because everything else in the parts lot was e body cuda.
Offline ec_co
« Reply #5 on: November 09, 2014 - 12:36:06 PM »
i know you have one piece, prob not worth the cost of the set just for the one part http://www.classicindustries.com/product/mopar/parts/me8135.html
ME8135 - 1970-74 MOPAR E-BODY REAR DEFROSTER/SPEAKER HOUSING
Replacement rear defroster/speaker housing for 1970-74 Mopar E-Body models. Manufactured from pot metal this housing mounts under the rear package shelf; houses the rear blower motor and passenger side speaker.
*edit: looks to be out of stock. but at least you know they make a repro. maybe Dave @ Roseville has em, or maybe C.I. can point you to the manufacturer?
*edit 2: a google search of "1970-74 MOPAR E-BODY REAR DEFROSTER/SPEAKER HOUSING" brought up a number of sites, including an original on ebay (needs total refurb though)
https://www.google.com/search?q=1970-74+MOPAR+E-BODY+REAR+DEFROSTER%2FSPEAKER+HOUSING&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=fflb
http://www.megapartsusa.com/proddetail.asp?prod=171-RD248&cat=537
http://www.early-birds.ca/part_3502_3665_3676-195713.html
http://www.ebay.com/itm/CUDA-CHALLENGER-Dodge-Rear-Window-Defroster-unit-E-body-Deluxe-duel-speakers-/351214209378
« Last Edit: November 09, 2014 - 12:48:14 PM by ec_co »
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline Rich G
« Reply #6 on: November 11, 2014 - 01:42:46 PM »
I have that piece sitting on my bench. Send me your address and I trace it out for you if you want.
Offline sleepie74
« Reply #7 on: November 12, 2014 - 08:09:09 AM »
thanks rich,,,pm sent
« Reply #8 on: November 12, 2014 - 06:55:32 PM »
EDIT: Found pics
This was a picture (green) of one on Alan's Barrelcuda.
So what one is right?
Speaker in front or back?
Offline ec_co
« Reply #9 on: November 12, 2014 - 07:24:18 PM »
i do not know the answer, but looking at the design I would have assumed the speaker would be up front - directly under the speaker grill. having the speaker fire into the metal/trunk would be useless. unless the idea is to use the speaker grill in the package tray to pull air from the cabin? i dunno, both seem valid
« Reply #10 on: November 13, 2014 - 05:38:06 PM »
 :feedback:
Offline ec_co
« Reply #11 on: November 13, 2014 - 06:20:31 PM »
I went forwards and backwards through the factory service manual and this is the closest pic I could find  :o     so I'm thinking logically about this (hahaha) and if I was designing it, the speaker would be towards the front and blower at the rear - this way sound quality isn't compromised and the blower can still draw air from the main cabin. if we want to get picky, the correct finish is Satin (per the manual), so the green pic is the correct finish, but the purple one is probably the correct fitment.
« Last Edit: November 13, 2014 - 06:23:28 PM by ec_co »
Offline sleepie74
« Reply #12 on: November 14, 2014 - 08:01:18 AM »
This is what i found---looks to me speaker is under the speaker hole cut into the adapter,,i would guess speaker is primary and the defrost is a secondary feature,,the adapter also has holes to mount to the speaker hole in the package tray...
Offline anlauto
« Reply #13 on: November 14, 2014 - 08:44:18 AM »
Yea...I had second thoughts on that installation too...I just put mine back the way I found it, but who knows with a 40 year old car whether or not someone was monkeying around with it before I got it. I never claimed mine was 100% correct. :2cents:
Offline ammo
« Reply #14 on: November 14, 2014 - 09:18:43 AM »
I saw a 1974 where it was bolted to the trunk hinge support.   Guy said it came that way and he was original owner....   Who knows....
1973 dodge challenger
