Yeah, that is a little higher than it should be. Look under it to see how many clips are holding it to the door. If my memory is correct there should be 7 or 8 on the front piece and 4 on the back. Before you try to pry it off note that one clips is actually a screw and bolt, so be care full not to bend the trim.
