Author Topic: 70 Challenger rear valance question  (Read 2708 times)
Offline roadman5312
« on: November 11, 2014 - 08:40:39 AM »
We ordered a Goodmark valance with no cut outs and received this. Does the no cut out valance mount differently than the cut out style ? I checked the part # on the tag and this is suppoed to be right  :dunno: Don't look right to me. Anybody else run into this ?
Offline anlauto
Re: 70 Challenger rear valance question
« Reply #1 on: November 11, 2014 - 08:46:23 AM »
Does it have a offset bracket on the other side for the license plate ?
Offline roadman5312
« Reply #2 on: November 11, 2014 - 08:50:15 AM »
Nope
« Reply #3 on: November 11, 2014 - 01:05:28 PM »
I thought 1970 was a one year only setup.  That looks like the 71-74 bracket in the middle.
Offline ToxicWolf
« Reply #4 on: November 11, 2014 - 01:09:12 PM »
I think it is a direct fit for 73-74 but can be modified for other years    :screwy:
Offline anlauto
« Reply #5 on: November 11, 2014 - 01:11:31 PM »
Yea, pretty certain they make one style to cover all the years. I'm sure you could modify it to your needs :2cents:
Offline roadman5312
« Reply #7 on: November 11, 2014 - 03:52:13 PM »
Thanks guys. This could be modified to fit a 70, but we got lucky and found an AMD. So this will go back. I'm still learning that when your looking for parts your often led to believe that that many 70 thru 74 parts are the same. Often not the case.
Offline shawge
  • Zoiks!!
« Reply #8 on: November 11, 2014 - 07:21:02 PM »
I think you'll be much happier w/ the AMD valance. I got both Goodmark and AMD versions of the Challenger valance w/ cutouts.  Big difference between the two.  AMD had thicker metal, crisper stamping, and the EDP was applied better.   It didn't feel as flimsy as the Goodmark version.
- Jerry
Offline roadman5312
« Reply #9 on: November 12, 2014 - 06:48:00 AM »
               Problem is AMD is out of stock. We had one on back order thru Summit for 2 months, cancelled it and exchanged for the Goodmark, which were not happy with. Yesterday foung an AMD on Amazon ( 1 left )  bought it, then they cancelled it because out of stock. So were still looking for one.
Offline shawge
  • Zoiks!!
« Reply #10 on: November 12, 2014 - 11:38:00 AM »
Have you tried Dave @ Roseville?  Any luck finding a decent original piece?
- Jerry
« Reply #11 on: November 12, 2014 - 12:16:53 PM »
You can also check Stephens Performance.  They had some discontinued pieces still in stock that I needed earlier this year.  Their website shows that the valance comes with the correct attaching brackets.
http://www.stephensperformance.com/rearvalance.html
Offline roadman5312
« Reply #12 on: November 12, 2014 - 12:28:10 PM »
Still looking, seems everybody is out of stock. Going to try Auto Body Specialties this afternoon. Thanks Burdar I'll try Stephens too.
Offline anlauto
« Reply #13 on: November 12, 2014 - 12:29:44 PM »
Yes, good point, there are a few vendors that stock AMD parts. I know I found a 1/4 panel at Tamraz's when everybody, including AMD was out of stock. :2cents:
Offline roadman5312
« Reply #14 on: November 12, 2014 - 01:33:27 PM »
Well I've called everyone, no stock anywhere. Just posted in parts wanted if anybody has one. Thanks.  :cheers:
