Author Topic: Alternator question??  (Read 5256 times)
Offline jmartin99
« on: November 11, 2014 - 09:56:54 AM »
I am trying to hook up a brand new engine wiring harness in a '72 Challenger with 340. According to the manual, there are three wires that go to the alternator. I have identified the three wires, the battery wire has a ring terminal on the end of it to be mounted on the stud on the back of the alt. The other two have female spade terminals The problem is I think the alternator I have is missing one of the male spade terminals to connect the wire to. Am I correct?   :1zhelp:
Thanks!
Jeff  :pullinghair:
Offline anlauto
Re: Alternator question??
« Reply #1 on: November 11, 2014 - 10:20:41 AM »
Yes, that's the wrong alternator. That is what they call a single field alternator used PRE-1970 :2cents:
« Reply #2 on: November 11, 2014 - 10:28:18 AM »
Also, when did the "square back" alternator start showing up?  My 73 has a square back.  Did 72 use one as well?
« Reply #3 on: November 11, 2014 - 10:39:47 AM »
Offline jmartin99
« Reply #4 on: November 11, 2014 - 10:40:50 AM »
I went to this alternator because the one specified for a 72 Challenger would not fit. The 340 has aluminum heads on it and this alternator barely clears the head.  Can I add the terminal tab under the existing screw and make it work properly?  :dunno:
Thanks!  :clapping:
Jeff
Offline jmartin99
« Reply #5 on: December 01, 2014 - 03:44:11 PM »
So with the new wiring harness, the wires that extend to the alternator has a black wire with a ring terminal that I am sure attaches to the Bat stud on the alternator. There is also a purple wire, a green wire and a tan wire. which two of these go to the alternator and does the third wire go to the A/C compressor? The alternator has terminals "FLD" and  "GRD", which colored wires go to these?  :dunno:
Thanks!  :cheers:
Jeff
« Reply #6 on: December 01, 2014 - 03:58:19 PM »
Look at the diagram "Topcat" posted.  You should have blue and green wires that connect to the alternator. Blue= field+...Green= field- but it will function the same if they are hooked up backwards.  The purple wire should have a rubber 90degree boot on it.  That's for the temp sender.  The brown wire goes to the electric washer motor if you have electric washers.  If you have a foot pump, the brown wire gets wrapped up around the three pronged clip attached to the alternator.
Offline jmartin99
« Reply #7 on: December 01, 2014 - 05:06:37 PM »
Hmmm...I see Topcats post, but it is empty...no diagram or text at all!
Thanks! This helps a lot!!!
Jeff  :thumbsup:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: December 02, 2014 - 05:36:42 PM »
Make sure you have the right spacers for the alternator.
If you don't you can crack the back half of the alternator off by over tightening it.
Don't ask...
« Reply #9 on: December 02, 2014 - 06:07:29 PM »
Jeff  :thumbsup:
If you don't see the picture yet I posted, send me a PM with your e-mail.
« Reply #10 on: December 02, 2014 - 10:56:41 PM »
Don't ask...
 :smilielol:  a bit of hindsight going on in your testimony :wave:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: December 04, 2014 - 03:19:15 PM »
Seen that travel commercial with Captain Obvious lately???
 :roflsmiley:
Offline jmartin99
« Reply #12 on: January 29, 2015 - 06:29:57 PM »
So from what has been said... Will it work if I connect the black wire to the Bat Terminal, the Blue wire to the Field terminal, A ground wire from the block to the Grd Terminal and leave the green wire disconnected?
Just trying to figure out how to hook this thing up!
Jeff
Offline tman
« Reply #13 on: January 29, 2015 - 06:48:20 PM »
I think its better to get the correct alternator with 2 fields.
« Reply #14 on: January 29, 2015 - 07:27:10 PM »
Yes that alt will work with a second tab added behind the screw as long as the second terminal has no connection to ground & is isolated
