Author Topic: Air Filter for 1970, E-body, 4 barrel with Shaker  (Read 1226 times)
Offline DocMel
« on: November 15, 2014 - 11:59:09 AM »
Need air filter cross reference for 1970, E-body, 4 barrel with Shaker.
 Looking for cross ref numbers for Fram, K/N if someone has them
Re: Air Filter for 1970, E-body, 4 barrel with Shaker
« Reply #1 on: November 16, 2014 - 10:19:29 AM »
Should be the std 6bbl oval A/C I would contact Dave @ Roseville , Fram was making them but quit again I believe , K&N still has them
Offline aarcuda33
« Reply #2 on: November 16, 2014 - 10:39:50 AM »
I believe he is referring to the round one goes under the orange lid
I believe it is Fram CA305V and you can cross reference that to other makers
Hope that helps
« Reply #3 on: November 16, 2014 - 10:44:40 AM »
I thought the smaller round one started in 71
Offline aarcuda33
« Reply #4 on: November 16, 2014 - 11:06:35 AM »
I don't believe so A 1970 shaker cuda anyway is a rare bird, used a different baseplate because of carb height but I am almost  positive it is the small round lid/ filter  I'm sure others will chime in
Offline DocMel
« Reply #5 on: November 16, 2014 - 11:58:17 AM »
Interesting    Plz continue/chime in if its a round or oval filter for a 70 equipped shaker
Offline DocMel
« Reply #6 on: November 16, 2014 - 12:06:55 PM »
Interesting site on filters and air cleaners for Mops from the 60's up   http://www.nicksgarage.com/aircleaner.htm
Looks like the '70, 383/440, 4 barrel, with Shakers, used a round air cleaner, with an round orange lid.  The lid is a little particular looking as it has a "lip" that extends downwards over the edge of the filter for about an inch or so
Offline tman
« Reply #7 on: November 16, 2014 - 12:09:06 PM »
Scroll down to "4bbl bubble kit".  Show round. Might get in touch with the seller to see what filter fits.
http://www.shakerhood.com/products.php?id=ShakerComponents
Offline tman
« Reply #8 on: November 16, 2014 - 12:21:06 PM »
Found this Fram Application site.  Click on the air filter part number and it gives a small cross reference chart.  Looks like CA305V as mentioned earlier.
http://www.framcatalog.com/Application.aspx?b=F
Offline DocMel
« Reply #9 on: November 16, 2014 - 03:59:48 PM »
Great input   It looks like the air filter lid on the 1970 Shaker equipped four barrels were all the same, 340, 383 or 440.  Its orange and looks like the same lid used on fresh air 69 Air Grabber models equipped with 4 barrels.   I guess the lids "overhang" was to keep water from splashing on the filter element
