Author Topic: 71 Cuda rocker molding clips?  (Read 1426 times)
Offline DocMel
« on: November 18, 2014 - 08:27:44 PM »
71 Cuda rocker molding clips:  Anyone know the proper clip mounting size and how many I need total?
Re: 71 Cuda rocker molding clips?
« Reply #1 on: November 18, 2014 - 08:35:58 PM »
Should be 6 per side I recall.
Offline DocMel
« Reply #2 on: November 19, 2014 - 09:17:37 AM »
Sorry, I should have been more specific  (At the time I originally posted, I thought on 71 models there was only the thin mouldling available)
I have the thin moulding:   The pic posted looks like it had mounted the pretty rare, wide moulding available on 71 models  (Grand Coupe option?)
Offline anlauto
« Reply #3 on: November 19, 2014 - 10:15:48 AM »
Nope I would say the picture posted was the narrow ones...you can see the out line of where they were :2cents:
Offline DocMel
« Reply #4 on: November 19, 2014 - 04:57:45 PM »
Now Im confused.  The outline shown looks much wider than the thin moulding I have.
Offline anlauto
« Reply #5 on: November 19, 2014 - 05:09:04 PM »
The moulding goes at the TOP of the rocker level with the door opening :2cents: You can see exactly where it was in that photo
« Reply #6 on: November 19, 2014 - 05:54:19 PM »
Check out this picture
It's a 73' but to my knowledge the position was in the same all years from 71' and on.
« Reply #7 on: November 19, 2014 - 06:52:44 PM »
I was looking at your thread Doc on the A pillar guages.
It appears your car was originally a Gran Coupe?
If that's the case, you'll have to weld up the rocker trim holes.
They sit lower that the river welded on studs.
You'll see in my picture where I welded mine up.
Prior to that, the trim was hiding the holes which was incorrect.
