Author Topic: Need Some Help With My Rearend! please  (Read 1594 times)
Plum6Pak
« on: April 30, 2005 - 09:28:55 PM »
I've never had any experience with a 9 1/4 rearend, anyone know if they are tougher than the 8 3/4? Found one out of a 74 B body and it looks very beefy indeed! Which would you use if given the choice? I know there would be some mods but if this is much tougher then maybe it would be worth it. I do know the housing is much tougher.  :dontknow:
Re: Need Some Help With My Rearend! please
« Reply #1 on: May 01, 2005 - 12:16:12 AM »
Ummm Yeah
 the housing is much tougher HAHAHAHAHAHAHA .... than what
 the 8 3/4 is stronger
 I break 9.25 rear ends with ease
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: May 01, 2005 - 09:26:46 AM »
Ummm Yeah
Did CP just make a FUNNY????    :eekbig:   :eekbig:   :eekbig:
Plum6Pak
« Reply #3 on: May 01, 2005 - 10:39:38 AM »
Ummm Yeah
HAHAHAHAHAHAHA .... than what.... Ummmm, I guess I assumed they were tougher cause they put it in HD applications in the heavy half ton trucks in place of the 8.75. I'll stick with the 489 suregrip. Just had a chance to trade someone for the rearend and didn't know for sure but if you brake them with the greatest of ease, better go with the proven one.
« Reply #4 on: May 01, 2005 - 06:22:42 PM »
Well Plumb6Pak,
   If Chryco is willing to go out on a limb and make a joke, then you better think that 9 1/4 rear isn't much.  :laughing:
« Reply #5 on: May 02, 2005 - 12:44:33 AM »
it should tell you something when they had them but never used them until the engines were all way down on power , the housing may actually be stronger carrying weight but is definatly is not better at taking HP, they still use them in trucks but not behind 500 ft lbs torque
Plum6Pak
« Reply #6 on: May 02, 2005 - 06:44:54 AM »
That makes sense and why would Chrysler spend the money for the more costly to build 8 3/4 if the need isn't there? Thanks Chryco, just wanted to make sure before I told this guy no.
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #7 on: May 07, 2005 - 03:55:16 AM »
Plum.....first glance at the subject.....i thought maybe you had a personal problem..... ;D
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Plum6Pak
« Reply #8 on: May 07, 2005 - 07:11:16 AM »
Hey DF, if that was the case, it'd be much larger than 8.75 and at my age the sure grip is gone!! Hahahaha, oops, shouldn't laugh so hard,  :eekbig:  Gotta run!
