OK Guys & Gals,
I talk to the owner today at the shop that was going to do my (expensive) media blasting/crossmember repair/primer. His frame rack is ready next week if I want to do it. So I tell him I want to get that done now and I am still checking out pricing on the rest of the job because he seems high. Then he starts telling me that he may have more time in the crossmember repair then we had originally talked about, he may need to remove it to make it look right
I told him if we were going to remove it I can do that myself and weld in a new one. So.....
I am back to probably dealing with this myself after I get some measurements and find out how much tweak I have if any.
For now I am going to probably do a couple of more things to get it ready and then send it to a guy that one of the members here turned me on to. They strip it and then epoxy powder prime the whole car inside and out for 1700-1900 all in. I talked to the guy today and really got a good vibe from him and he has great references.
If everything measures out ok I may drill the spot welds out of the floor to crossmember, anyone who has had it apart know if you can pull the crossmember without removing the floor if you get all the welds cut?
I figure if I replace the crossmember and weld in SF connectors before I have it primed it will be cleaner and easier to do.
I think I have hit the paralysis by analysis stage.
All feedback is appreciated
Greg
