Author Topic: trans cooler line install  (Read 734 times)
Offline jaymancuda
« on: November 23, 2014 - 02:22:31 PM »
I have 68 Barracuda fastback with 318 and 727 trans. I ordered stainless steel lines and during installation they go to different ports on radiator. does it matter how they hook up at radiator? The originals went from left side rad to front port on trans the new one goes from same radiator port to rear port on trans. Is there a specific flow to follow?
Re: trans cooler line install
« Reply #1 on: November 23, 2014 - 06:50:07 PM »
not with a horizontal flow in & out through the lower rad tank can go either way ,
vertical tanks have to flow downward
Offline jaymancuda
« Reply #2 on: November 27, 2014 - 01:53:33 PM »
thanks for info. it is a horz tank at bottom of rad. soon as I get chance I will start to post pictures of both the 68 fastback & 73 cuda.
