Author Topic: Sparkplugs!  (Read 3108 times)
Offline 74 challenge
Sparkplugs!
« on: November 25, 2014 - 09:20:56 AM »
I am trying to get my order together to take advantage of some Black Friday Deals (thanks America!) and had a question about sparkplugs because my car is in storage right now and cannot pull a plug to see what ones I am running.
What is a decent plug? I think it was Chryco that suggested some Champion plugs awhile ago and they were working awesome before my carb fouled them up. They were fairly cheap too.
I was thinking about these ones: http://www.summitracing.com/parts/cpn-3405
it's a 318 with some taylor plug wires, accel coil, edelbrock intake and otherwise pretty stock.
1-8-4-3-6-5-7-2
Re: Sparkplugs!
« Reply #1 on: November 25, 2014 - 03:13:51 PM »
I would use either RN12YC or RN14YC Summit is using a different part# 3403 for example so I am not sure if it is correct .
Offline cudabob496
Re: Sparkplugs!
« Reply #2 on: November 25, 2014 - 05:26:01 PM »
lotta folks like NGK
2011 Kawasaki Z1000
Offline AARuFAST
  • AARuFAST
Re: Sparkplugs!
« Reply #3 on: November 25, 2014 - 10:39:15 PM »
Champion copper for Mopars  Use a hotter plug if fouling.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline cudabob496
Re: Sparkplugs!
« Reply #4 on: November 25, 2014 - 11:25:37 PM »
from my experience, if plug fouling, its due to something else other than the selected
heat range of the plug.
2011 Kawasaki Z1000
Offline jimynick
Re: Sparkplugs!
« Reply #5 on: November 28, 2014 - 10:54:36 PM »
You're right, but the hotter plug will help crutch those loose valve guides and/or rings for a while.  :cheers:
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: Sparkplugs!
« Reply #6 on: November 29, 2014 - 12:41:50 AM »
RN12YC in my 418 stroked 340  :2cents:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline cudabob496
Re: Sparkplugs!
« Reply #7 on: November 29, 2014 - 06:23:42 AM »
yep, at that point, whatever helps!
2011 Kawasaki Z1000
Offline whitewatersky
Re: Sparkplugs!
« Reply #8 on: July 22, 2016 - 01:01:41 AM »
i pulled mine yesterday after it was missing
very black
I just put NGK 2828 / BPR5EY in and it's running very nicely
Converter shows Champion RN12YC to be equivalent, like Chryco Psycho recommended.
last set were DENSO W16EXR-U which show as another like set
Mine is running SUPER rich but we'll see how these go
need to keep fine tuning the carbies tho...
« Last Edit: July 22, 2016 - 01:04:13 AM by whitewatersky »
Plum Crazy auto T/A Challenger
Offline Finoke
Re: Sparkplugs!
« Reply #9 on: July 22, 2016 - 07:25:34 AM »
How is the heat range of a plug designated? I finally got the jetting of my carbs close to where it should be for my car other than tuning by O2 Spenser.  I never really understood how a plug can be hotter and how to tell if one plug is designated hotter than another.
Re: Sparkplugs!
« Reply #10 on: July 22, 2016 - 09:15:09 AM »
The distance from the electrode throught the ceramic back to the steel body of the plug determines hot hot the plug will stay , shorter distance & the heat is easily dissapated to the head longer distance more heat is retained
Offline Finoke
Re: Sparkplugs!
« Reply #11 on: July 22, 2016 - 10:05:59 AM »
Thanks Chryco that makes sense. So how do you select a plug for any given engine. Is there a designation for the degree of heat from plug to plug that will fit the same engine?
Re: Sparkplugs!
« Reply #12 on: July 22, 2016 - 11:31:39 PM »
too hot will cause detonation
too cold will not burn off the contamination & foul
Offline Finoke
Re: Sparkplugs!
« Reply #13 on: July 23, 2016 - 12:57:41 AM »
Excellent, thanks :2thumbs:
Offline barnett468
Re: Sparkplugs!
« Reply #14 on: July 28, 2016 - 12:35:32 PM »
I run all the engines I build at 185 degrees . 195 degrees and higher can promote detonation, especially in hot climates.
I typically use the stock heat range in engines with around 160 psi of cranking compression . If it is higher than that, I will often drop down to the next coldest plug . I rarely use plugs that are 2 steps colder than stock.
I also set the timing "curve" so it is optimal for each engine . Insufficient timing can cause hot running conditions.
