hurst 5 speed convertion
Author Topic: hurst 5 speed convertion  (Read 1190 times)
Offline rmsolimando
« on: November 25, 2014 - 06:52:44 PM »
Hello All
I just bought Hursts ELITE KIT 5 speed kit and had a few questions. I am converting from an auto to stick. I do know i need a 4 speed hump and pedel assembly. what is confusing me is the mechanical linkage. are there kits out there that are every thing i would need. I tryed buying this stuff individually but i know im gunna leave stuff out. Is there a kit out there? Does anyone have a full parts list of what i would need for the linkage? Other than the hump, pedels, and linkage am i missing any thing else? The car is a 1973 auto with 440. any advice would be greatly appereated.
Regards,
Offline bigblue73
Re: hurst 5 speed convertion
« Reply #1 on: November 25, 2014 - 07:54:45 PM »
Hi Rob -  I'll post to this in the morning.  I have a very comprehensive list that I shared with customers when I rep'd for Hurst.  Sit tight - I got ya!
Offline jhaag
« Reply #2 on: November 25, 2014 - 08:12:46 PM »
Are you dead set on mech. linkage? Might want to think about hydraulic. Can do it for about half the cost if you don't mind a little fabricating.
love 70 Challengers
Offline rmsolimando
« Reply #3 on: November 25, 2014 - 09:23:11 PM »
Thanks bigblue73 look foward to reading it.  jhaag i am kinda set on a mech. linkage i have driven both and prefer it over the hydraulic set up.(At least the hydraulic set up i drove)
Offline bigblue73
« Reply #4 on: November 26, 2014 - 09:39:50 AM »
Following are the required additional parts to complete an automatic to 5 speed conversion for a 1970 to 1974 Dodge Challenger and Plymouth ‘Cuda.  Note: That if using a hydraulic throw out bearing system, the mechanical linkage only items will NOT be required.
Brewers Performance - Phone: 937-698-4259
4 Speed Tunnel Sheet Metal
Brewers #: FT-160         $140.00
   A four speed tunnel hump must be install for all E-Bodies and Second Gen. B-Bodies
Shifter Boot Screws
Brewers #: SBBS  (Qty. 4)       $ 1.00 ea.
P&G Classics – Phone: 888-473-5855
#241      70-74 E-Body Pedal Kit      $195.00
#259      70-74 E-Body Pedal Bracket   $ 19.00
#212E   E-Body Z-Bar         $ 59.00   (Mechanical Linkage Only)
#225-PE   E-Body Pedal Push Rod      $ 19.00 (Mechanical Linkage Only)
#241-P   Clutch & Brake Pedal Pads   $  8.99 ea.
      70-74 E-Body (2 Required)
#132-E   E-Body Shifter Boot      $ 39.00
#301      E-Body Shifter Ring      $ 18.00
#208      70-74 E-Body, 71-74 B-Body   $165.00 (Console equipped cars ONLY)
      4 Speed Console Plate w/ Wood Grain Insert
Mopar Performance – Available from your local Dodge Dealer
   Provided cost are estimated only.  Actual pricing may vary based on local dealer pricing structure.
P4529452   Clutch Fork Kit – 10 ¾” Long, Small Block E- and B- Bodies $ 99.00 (Mechanical Linkage Only)
      Includes Clutch fork, mounting bracket and Fork Boot
P4529453   Clutch Fork Kit – 10 ¾” Long, Big Block E- and B- Bodies $ 99.00 (Mechanical Linkage Only)
P4529447   Clutch Linkage Shaft Service Kit  B & E Bodies   $ 55.00   (Mechanical Linkage Only)
      Kit include all the delrin bushings, snap rings, ball ends and seals.
P4529450   Clutch Rod Kit – 4.880 Overall Length – B & E Bodies   $ 59.00 (Mechanical Linkage Only)
      Kit is the adjustment rod from the z-bar to the clutch fork and all required adjustment hardware.
P2843892   Clutch Inspection Cover  $32.00
      The clutch inspection cover is required with the Classic Mopar 5 Speed cast small block bell
      housing.  A total of five (5) – 5/16-18 x 1/2” long Hex Fling Lock Screws with serrations are
         required for attachment (Classic Mopar 5 Speed part number: 3562-1050)  $5.00
Offline rmsolimando
« Reply #5 on: November 26, 2014 - 11:33:21 AM »
thanks bigblue ill order this stuff up.
Regards,
