Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
rally ac/heater switch for non ac
« previous
next »
Print
Pages: [
1
Author
Topic: rally ac/heater switch for non ac (Read 1069 times)
brotow
Full Member
There really is a Challenger in the backround
on:
November 26, 2014 - 07:16:19 PM »
I am using a rally ac/heater switch with a non ac heater box, would it work correctly? The vacuum lines cannot be used, will the switches control the heater, defroster, etc?
Last Edit: November 28, 2014 - 03:29:10 PM by brotow
Logged
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
TedOrlowski
Newbie
Re: rally ac/heater switch for non ac
Reply #1 on:
November 26, 2014 - 09:04:26 PM »
You need the vacuum to change the position of the switches inside the heater the on off switch will not work
Logged
shawge
Full Member
Zoiks!!
Reply #2 on:
November 26, 2014 - 11:33:07 PM »
You're trying to hook up an ac bezel on on non-ac car?
I think the switch to control the fan speed interchanges - the wiring diagram seems to indicate that it would.
The non-ac bezel has heat and temp levers. The ac bezel has the temp lever. You might be able to get temp to work.
The ac bezel used the vacuum lunes for ac/heat/defrost as you mentioned.
Logged
- Jerry
brotow
Full Member
Reply #3 on:
November 28, 2014 - 07:36:49 PM »
Yes will be using a rally ac switch panel on a non ac heater box. As far as I figured, the vacuum lines control the actuators on the "blend" doors. Maybe one door opens and closes for heat or defrost another door for ac. I think the cable could work on the non ac box to switch from heat to defrost.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
