Author Topic: 1973 'CUDA 500 CID 200+MPH Fer sale UPDATED PHOTOS  (Read 1283 times)
Offline Bobfish
« on: November 26, 2014 - 07:58:09 PM »
"Relationship Issues"   are the root cause of this sale. Plus Im at odds with the folks at Silver State over my DQ a couple of years back. Anyway selling my '73 'Cuda, Location Denver metro, Price, asking 35,000.00 but will entertain other numbers. You can email me directly at schrhATjunoDOTcom with any questions not coverd here. UPDATED PHOTOS taken today of "STREET VERSION" Bob
With a pedigree of some 14 Open Road Races, most of which have maintained speeds of 160-190 mph. Arguably the fastest (not quickest) real 'Cuda on the planet. https://www.youtube.com/watch?v=Vh09RK2GLP4  Turns 2000 rpm at 80 mph on the highway in 4th. This "Fish" will cruise at 195mph....'nuff said......
A couple of things up front.....
This is NOT a show car, or trailer queen. I would prefer to sell to someone who will continue to race the car. The car is STREET LEGAL in Colorado. Yes it could be "brought back" to stock HOWEVER it would need a new dash pad and trunk floor. The cage and seat reinforcing plates could be removed but the frame connectors would be a major issue so I would advise against removing them. Plus they strengthen up the "frame" (no flex) considerably.
Original equipment power steering setup, power brake setup, and wipers with motor included. Also race nose piece, air dam, side skirts, straight pipe exhaust, and forced air box to radiator included.
TRANSMISSION
833 Overdrive Stock Chrysler
Pistol Grip
3rd Gear is 1:1
4th Gear is .73:1
All new seals and gaskets,
All internals have been Cryogenically treated for added strength.
500" MOTOR PARTS
Block Stock Iron Date Coded 5-18-77
Stock Timing Cover and Balancer
Balancing By Denver Balancing
Indy Alum Max Wedge Heads
All Head work, Porting by Hughes Engines
Eagle Crankshaft And H Beam Rods
CP Pistons Rings and Pins
All Bearings are Clevite with Calico Coatings
Billet Main Seal 2 piece from Mancini Racing
Howe Alum Radiator
Cometic MLS Head Gaskets
MSD 6AL Ignition
K&N Breathers
Custom Air Cleaner with K&N element and filtered lid
Accel 8mm wires
Open cooling system (no thermostat) Spaal electric fan.3 inch street magna flow mufflered exhaust. 3 inch straight pipe race exhaust. Both turn out in front of rear wheels.
Hughes Engines Solid Camshaft,Lift .587/.594 With 1.5 Rockers, Duration @ .050 260/264 Lobe Sep 108', Solid Lifters, Custom Cut Pushrods, Rocker Shafts,Valve Springs, Over size Intake vakves, One Piece Valley Pan
Mopar Performance Oil Pump, Hemi Oil Pan, Windage Tray,Water Pump and Housing, Electronic Distributor, Valve Covers, Oil Pickup, Dist Drive Shaft. Mechanical advance set at 34 degrees max.
Edelbrock Single Plane Intake, 440 Super Victor, Ported and polished by Hughes Engines
Holley 1000 cfm Carb, No Choke, Mech Secondaries, Performance modified by Bill Pink Carbs
DRIVELINE AND AXLE
All parts are new when rebuilt and put together with any heavy duty applications I could find. 2.76 Ratio hogs head with stock bearings. Drive shaft is .030 thicker than stock. Tires are Michilen PS2's Y rated at 180+.
SUSPENSION & BRAKES
Basically a stock setup with disc rears and fronts. Not power set up. Torsion Bar (Hemi) the fatest I could get from M.P. KYB shocks. FatMan Fabrication Drop Spindles. Rear leafs (Hemi) with coil over shocks. Manual steering. Stock front and rear sway bars. Custom built panhard bar.
SAFETY
5 LP supression fire system with 5 nozzles. 3 pound hand held. Full 6 point roll cage 4 mounted in the frame connectors with roof ladder bar and "spiders web" behind seats and extends into trunk with another cross bar and 2 points in reinforced plates. Removable door bars. Fuel Safe 25 gallon fuel cell with foam insert. Engine restraints. Fuel line routed through cab in a hard line pipe. Sparco seats with 5 point harnesses mounted to reinforced floor pans (plates). Aluminum seperator between cab and trunk (fuel cell). Inversion switch, this disconects power to the fuel pump in the event of a roll over, so no motor run on. External fuel cut off switch on taillight panel. Fuel pump cut off switch on dash and master battery kill switch on roll bar at drivers reach. Quick release steering wheel with center pad. Scatter shield and SFI bellhousing. Driveshaft Loop. Window nets. In short this car will pass tech for any ORR events Unlimited Class.
BODY
Body is in great condition and straight. Was originally from south Ca. south of Palm Springs so no salt air. Did have the typical front and rear wheel areas on both sides but they were minimal and have been repaired. No other past rust to mention.
ADDITIONAL
Full set of Autometer gauges, Fuel, water temp, oil temp, oil press, vacuum, EGT, 2 air fuels, voltmeter, tach, speedo, xmsn temp, axle temp.
Set up for xmsn oil cooler but not completed. Elec fuel pump. Alum radiator.
No back seat.
FM/CD radio.
« Last Edit: November 28, 2014 - 04:37:46 PM by Bobfish »
