Author Topic: Best pistol grip shifter replacement?  (Read 2744 times)
Offline Zack Mckellips
« on: November 26, 2014 - 10:56:23 PM »
This has prolly been on here, but I did a search and couldnt come up with anything,  I have a 73 challenger that was and auto and I switched to 4 speed a few years ago using mostly used parts including the shifter, it is a little sloppier than I would like , it's a factory style  with slip in handle, but now I want a new one , so what is the best way to go , I seen some e- body ones on ebay , but there is also a t/a AAR version,  what is that? Also I seen some have stops in them is there any other good options for a bolt in shifter , it don't see anything straight from hurst , just on ebay
Re: Best pistol grip shifter replacement?
« Reply #1 on: November 26, 2014 - 11:03:11 PM »
Your shifter handle were 2 possible choices:
Splined or smooth.
Brewersperf can get you the right one.
Offline bigblue73
« Reply #2 on: November 27, 2014 - 12:42:32 PM »
Reproductions are made by gunslinger for hurst.  These reproductions are like jewelry and flat out perfect.  The 70's only had the spline with 71-74 receiving the smooth and two bolt retention.
Offline anlauto
« Reply #3 on: November 27, 2014 - 01:59:10 PM »
Actually the 1970 "clip-in" style are smooth, while the 71-74 are splined requiring two bolts :2cents:
Offline bigblue73
« Reply #4 on: November 27, 2014 - 03:05:24 PM »
I stand corrected!
« Reply #5 on: November 28, 2014 - 04:21:21 PM »
The one I have now is clip in , and I'll be using that handle, can I just drill the holes in the handle then? Also what is the T/A AAR one I seen ? I didn't know there was a difference?  Any tighter maybe?
« Reply #6 on: November 28, 2014 - 04:23:34 PM »
I think I want one with stops the factory one I have now does not have stops maybe that's why it's more worn out?
« Reply #7 on: November 28, 2014 - 04:27:13 PM »
I looked up gun slingler,  I only seen handles, my pistol grip handle is good,  the shifter mechanism is worn out
« Reply #8 on: November 28, 2014 - 10:37:14 PM »
http://www.brewersperformance.com/proddetail.asp?prod=H0001
or send it to them and they'll re build it
Offline anlauto
« Reply #9 on: November 29, 2014 - 08:43:15 AM »
Yes you can drill your handle.
AAR, T/A' s used the same shifters as every other Cuda or Challenger...
« Reply #10 on: November 29, 2014 - 10:52:14 AM »
Ok thanks guys
Offline HemiOrange70
« Reply #11 on: November 29, 2014 - 11:37:12 AM »
[/quote]
Apparantly not when selling on Ebay-they are really rare  :poopoke:
« Reply #12 on: November 29, 2014 - 11:10:42 PM »
Brewers, Passon, or even Hurst can rebuild the mechanism to eliminate the slop and smooth up  the action. Inquire with them to get costs and process for sending it in.
FWIW, I had Hurst rebuild a V-Gate shifter I had a few years back. Worked like new once I got it back.
