Author Topic: K-frame stand  (Read 8679 times)
Offline soundcontrol
K-frame stand
« on: November 27, 2014 - 05:55:27 PM »
Soon I will remove the engine, transmission and suspension on my car and I wanted to build a K-frame stand. Now when I start thinking about it I have a few questions. Whats a good height from the floor to the K-frame? I guess as low as possible to avoid lifting the car so high, on the other hand comfortable enough to work on the package when its out. 10-12" maybe? Maybe make it adjustable? Is it a good idea to have some support for the back of the engine also? (If I remove the transmission). Is one wheel enough in the back under the transmission mount? Was planning on making it like a T with 2 wheels up front and one in the back. I also thought of bolting the long part to the shorter instead of welding so I can take it apart for easier storage. Anything else I should think about?
/ Ken
topic=108917.new#new
Offline anlauto
Re: K-frame stand
« Reply #1 on: November 27, 2014 - 05:58:52 PM »
The width of the base can't interfere with the width of your engine hoist if you want to lift an engine on and off properly  :2cents:
Re: K-frame stand
« Reply #2 on: November 27, 2014 - 06:06:02 PM »
Right! Did not think of that. Good point.
/ Ken
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: K-frame stand
« Reply #3 on: November 27, 2014 - 06:17:20 PM »
Made mine ride height of the car, This way you can bolt the whole suspension on it and make assembly much easier
Re: K-frame stand
« Reply #4 on: November 27, 2014 - 06:55:22 PM »
Nice! Wish I had that nice lift...(and the engine). Height looks good for working on it, but at ride height, isn't it difficult to get it in place? (with no lift). I gotta raise my car in the front, with the rear wheels on the floor. I have to raise it a bit to get the stand in under, then lowering the car on to the stand is gonna be at an angle...hmm.
The support under the trans. is gonna make contakt first. Seems to me that I need a jack under the K-frame, then loosen the bolts and then
lower the whole package on to the stand, then lift the car higher and roll it out.
« Last Edit: November 27, 2014 - 06:56:57 PM by soundcontrol »
/ Ken
Offline 750-h2
Re: K-frame stand
« Reply #5 on: November 27, 2014 - 07:42:02 PM »
anlauto. Any chance that you can post a picture of your K frame cradle? I know you work on mostly original cars and use an engine lift so it would be nice to see how you made yours.
Thanks
Offline anlauto
Re: K-frame stand
« Reply #6 on: November 27, 2014 - 07:43:36 PM »
anlauto. Any chance that you can post a picture of your K frame cradle? I know you work on mostly original cars so it would be nice to see how you made yours.
Thanks
You would laugh if you saw how I do it....
Re: K-frame stand
« Reply #7 on: November 27, 2014 - 07:46:38 PM »
Here is one I made.
I never did use it. But I did use it to put the entire front end parts on.
What i ended up using were 2 moving dollies connected together with bracing to put the whole assembly in.
Offline 750-h2
Re: K-frame stand
« Reply #8 on: November 27, 2014 - 07:55:55 PM »
You do it often enough so it must work pretty good! Sometimes simpler is better. :thumbsup: I need to build one soon so I would love to see yours
Re: K-frame stand
« Reply #9 on: November 27, 2014 - 07:59:55 PM »
Offline 750-h2
Re: K-frame stand
« Reply #10 on: November 27, 2014 - 08:07:54 PM »
Thanks! All good ideas. I plan on using an engine lift to raise the front of my car, so k frame stand will have to be built low to the ground.
Offline anlauto
Re: K-frame stand
« Reply #11 on: November 27, 2014 - 09:17:29 PM »
Okay...YOU asked for it. Please keep in mind I've been installing motors from the bottom since 1993. Over two dozen drive trains have been installed using this set-up.
It's simply three pieces of 2X2 square tubing welded in a "U" shape, with four rotating caster wheels. Covered it in some old towels and duct tape so it won't scratch the K Frame. :icon16:
I have to admit I laugh a little when I see the huge over-thought carts that people make... :screwy:
Offline anlauto
Re: K-frame stand
« Reply #12 on: November 27, 2014 - 09:22:23 PM »
I've used it with 340's all the way up to 426 Hemis
Action shot...
Offline twalker
Re: K-frame stand
« Reply #13 on: November 27, 2014 - 10:08:42 PM »
Here's mine
Offline 750-h2
Re: K-frame stand
« Reply #14 on: November 28, 2014 - 09:13:58 AM »
Anlauto, thanks for posting the picture! Simple but functional!
« Last Edit: November 28, 2014 - 10:53:58 AM by 750-h2 »
