Author Topic: Using a hand lever for the emergency brake?  (Read 1953 times)
Offline dakota
« on: November 28, 2014 - 03:18:05 PM »
When I was taught how to drive on an stick shift a couple of centuries ago, the lessons included starting from a dead stop on some steep inclines.  This involved using a hand lever to gradually release the e brake to avoid rolling backwards into the car that was inevitably too close behind me.   I was curious if there are any examples of Challengers or others using a hand lever like what Lokar offers instead in the pedal e brake.  I was not planning to have a console in my car, but one immediate complication of installing a hand lever is that adding a console later would be a bigger pain.
I'm not against learning how to use the pedal version, but it seems like one less thing to screw up when I'm finally driving the Challenger.
Re: Using a hand lever for the emergency brake?
« Reply #1 on: November 28, 2014 - 05:39:26 PM »
Anything is possible with a little work/money applied to it. Drifters add seperate right/left hand brakes to help pitch their car into a slide.
You could offset this lever to the side of the tunnel next to the seat if you wanted a stock console later. Or come up with a modified console deisgn to accomodate the brake lever.
Offline drewcrane
« Reply #2 on: November 28, 2014 - 05:53:25 PM »
Yep seems doable ,and make a console to fit after it is mounted,cut up and old console,make it fit :stirpot:
Offline moprr
« Reply #3 on: November 28, 2014 - 06:31:34 PM »
A member here beck did that in his build tread.  I bought the Loklar hand brake and will also be doing the exact same thing he did.  If you review his build you can see the exact location beside the seat.
« Reply #4 on: November 28, 2014 - 08:33:24 PM »
When parallel parked on a steep hill, use your line-lock, do a massive burnout, and pull away!
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #5 on: November 28, 2014 - 10:18:30 PM »
Parked or stopped at a light on a hill.  :2thumbs: Smoking massive burnout optional!  :burnout:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #6 on: December 08, 2014 - 08:58:00 PM »
something like this ?
« Last Edit: December 08, 2014 - 08:59:51 PM by johns cuda shop »
Offline dakota
« Reply #7 on: December 08, 2014 - 10:42:44 PM »
John - that's the idea, except I wouldn't have the cool console to go with it.   For this e-brake handle location, what did you or will you do for the e-brake cables - a customer order length, or is there an available  part that works?
Offline falkenracing
« Reply #8 on: December 09, 2014 - 01:26:25 AM »
Planned on might doing this on my bee in the future, but I'm looking to place the lever like on the old volvo 122-142 series, on the left of the drivers seat.
Might be worth looking in to?
Offline grimmey71
« Reply #9 on: December 09, 2014 - 01:35:03 AM »
I had the lokar, and got rid of it. I grabbed one out of a dodge stratus. $10 from pick a parts and very stout. Plus it's longer and has more of a modern feel. Sorry no pics right now as car is out away for winter
« Reply #10 on: December 09, 2014 - 12:28:26 PM »
You can get the universal cables online , I got mine off the Speedway Motors Website. The lokar handbrake works great and very adjustable,  :bigsmile:
