Author Topic: Speedometer Restore  (Read 3471 times)
Offline Chooch
Speedometer Restore
« on: November 29, 2014 - 04:56:38 PM »
I would like to send off my OEM Speedometer for restoration.  Any ideas on a good place to send it ?
Offline Racer57
Re: Speedometer Restore
« Reply #1 on: November 29, 2014 - 09:07:20 PM »
Offline tx9aarcuda
« Reply #2 on: November 29, 2014 - 09:08:11 PM »
I have not used them but I have heard good things about Reline Gauge Works
http://www.redlinegaugeworks.com/
Greg
68 Coronet R/T Convertible 4 spd
70 AAR Auto
97 Ram 1500
« Reply #3 on: November 29, 2014 - 09:50:41 PM »
Mr. Heaterbox.com is another to consider with a reasonable cost and a fast turn around.
also known as Premiumdashdecals.com
http://www.mrheaterbox.com/instrument_clusters.htm
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: November 29, 2014 - 10:14:58 PM »
http://www.redlinegaugeworks.com/default.asp
 :iagree:  Sent my entire gauge cluster to them and it came back immaculate!
Offline ShelbyDogg
« Reply #5 on: November 29, 2014 - 10:33:35 PM »
What do they charge for a speedometer? Brand new ones are $350 and available everywhere now.
« Reply #6 on: November 29, 2014 - 10:41:24 PM »
if you plan on replacing an OEM guage with the new aftermarket.
The color of the speedometer needle will be significantly brighter color than any of the other original gauge needles you plan on continuing using.
If you plan on buying a new reproduction guage, then I suggest painting the rest of the neeedles to match the same hue or replace all of them.
Otherwise, it'll look funky.   :2cents:
Offline Chooch
« Reply #7 on: November 30, 2014 - 05:50:01 PM »
Thank you guys very much.
Offline BIGSHCLUNK
« Reply #8 on: November 30, 2014 - 09:25:30 PM »
I've had redline do work on some of my stuff but for my tach & speedo I stayed local. http://speedometersolutions.com/
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline dfrazz
« Reply #9 on: November 30, 2014 - 10:44:28 PM »
I'm not sure on just the speedo, I had a new tach and oil pressure gauge installed, moved the fuel over, cleaned up the lens and refurbished my speedo.  Give them a call and they will give you a quote.
Offline Road_Runner
« Reply #10 on: December 08, 2014 - 04:19:26 PM »
Did you have this done to standard or rally gauges?  I've seen a few pics of Redline's work on standard gauges and I thought about adding an oil pressure, moving the fuel gauge to the far left and redoing the speedo to 160 mph.  I have a period correct tach & housing that I'll just add to the steering column if I go this way.  If you have any pics of your dash I'd love to see them.  Thanks.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline dfrazz
« Reply #11 on: December 08, 2014 - 04:24:40 PM »
Later, Jim
Here you go....
Offline Road_Runner
« Reply #12 on: December 08, 2014 - 04:29:20 PM »
Here you go....
Thanks those look great!  So you just lost the ammeter and added a tach & oil pressure gauge.  Interesting, hadn't thought about doing that?  Their work looks really good though, leaning heavily toward using them for both of mine.  Thanks again for sharing!
Later, Jim
Offline dfrazz
« Reply #13 on: December 08, 2014 - 04:32:52 PM »
Later, Jim
And moved the Fuel gauge, yes.  They reset the odometer, re-calibrated the speedo and polished the lens too.  Took about 5-6 weeks.  I am thinking of doing it again on my '70 Cuda.
