Author Topic: Headlight adjust kit/headlight bezel/ headlight buckets. 1973 Challenger  (Read 4510 times)
Offline challenger_73
Does anyone have intructions on attaching the headlights back to the header panel? I took everything off when i sent it off for body and paint. It's been so long. I forgot how to put everything back on and adjust the headlights. Any help would be appreciated. Thanks.
Challenger_73
Offline dakota
Re: Headlight adjust kit/headlight bezel/ headlight buckets. 1973 Challenger
« Reply #1 on: November 30, 2014 - 07:48:59 AM »
I have a 70 Challenger service manual with several pages associated with the headlight assembly and aiming.  I don't know if it's identical to a '73 but I would think they would get you going in the right direction.   If you want copies of these pages, PM me your email address for a digital version or mailing address for paper copies.
Offline jimynick
« Reply #2 on: December 01, 2014 - 10:40:14 PM »
There should be 2 rectangular openings at each h/lamp mounting spot where the adjusters shove in from the rear. You'll also note a small screw hole for the retaining spring if memory serves. The h/lamps use a 2 point mount and one spring system. You can start the h/lamp buckets in the aimers by hand and a piece of stiff wire with a hook bent in it's end will pull the spring out to hook in the notch in the mounting ring. The h/l's are aimed by turning the aiming screws until The lights align and are on target. There were lots of sealed beam aimers in the day, so ask around at any old garages and they may dust one off for you; otherwise, the garage door makes a pretty good aiming tool High beam or 2 prong lights go in the inner position and low, 3 prong lights go outboard. hope that helps.  :wave:
« Reply #3 on: December 02, 2014 - 12:30:13 AM »
I scored one for free years ago.
Hard to find.
« Reply #4 on: December 02, 2014 - 09:58:30 AM »
The buckets are color coded so they get put in the correct place.  Is there any paint left on yours?
« Last Edit: December 02, 2014 - 10:06:46 AM by burdar »
« Reply #5 on: December 07, 2014 - 12:33:16 AM »
Oh great! I painted my buckets. I have no idea which  goes where. Is there any other way to tell?
Offline anlauto
« Reply #6 on: December 07, 2014 - 09:15:07 AM »
There all stamped on the front of the outer rim LH LO, RH LO, RH HI LH HI
« Reply #7 on: December 07, 2014 - 10:50:31 AM »
Thanks anlauto! I have two sets of four from two different cars. One set is painted and one set is not.  I see the stampings on both but it is faint on both sets. If i'm correct This is what I see.
HI-5-RT-118
HI-5-LT-119
HI-LO-5-RT-122
HI-LO-5-LT-123
challenger_73
« Last Edit: December 07, 2014 - 11:19:34 AM by challenger_73 »
« Reply #8 on: December 20, 2014 - 04:47:35 PM »
I have not touched my car since the last post. I know which side that the buckets go on. I am just trying to figure out which is the  inner and which is the outer. can anyone tell me if i am correct or not?
Hi-5-Rt-118 = high beam right side inner
Hi-Lo-5-Rt-122 = low beam right side outer
Hi-5-Lt-119 = high beam left side inner
Hi-Lo-5-Lt-123 = high beam left side outer
Offline anlauto
« Reply #9 on: December 20, 2014 - 05:39:04 PM »
Yes
« Reply #10 on: December 20, 2014 - 05:55:17 PM »
Great! Thanks a million. I was stuck on that. Your the man!  :thumbsup:
« Reply #11 on: December 20, 2014 - 06:06:44 PM »
The last one should have been
Hi-Lo-5-123 = Low beam left side outer.
I made a mistake. Just for future reference for anyone looking at this thread.
challenger_73
Offline jimynick
« Reply #12 on: December 21, 2014 - 02:42:46 PM »
The high beams are always in the inside position on N American cars and the aimers are usually at the top and on the outside of the buckets- outside being away from the centre of the car. Think of the old 64 Thunderbolts and their ram air tubes in the inside (high beam) position. The outer or low beams have 2 filaments, that's why they have 3 prongs and they light for both low AND high, while the 2 prong inners have only one filament and  light only for high. Capice?
« Reply #13 on: December 21, 2014 - 10:29:12 PM »
Got it! Thanks much! :2thumbs:
