Author Topic: 70 RT SE Challenger question  (Read 3306 times)
Offline Jshort
« on: November 30, 2014 - 01:43:12 PM »
Hello, great forum, new guy with a simple question. I'm no expert to say the least however, I'm looking at a purchase of a 70 Challenger, it's a real RT / SE but.... It has the large back window without vinyl top, is this possible? I thought SE only came with vinyl top small window, car shows no sign of ever having a vinyl top but would look much better with one installed IMHO, or could there have been a vin plate change, it looks as though it's never had the tags altered or removed, thanks for any help at all!
Offline anlauto
Re: 70 RT SE Challenger question
« Reply #1 on: November 30, 2014 - 01:52:57 PM »
Does the VIN plate state RT/SE ? Does the body stampings on the cowl and rad support match the VIN ? That's where I would start.
Offline Jshort
« Reply #2 on: November 30, 2014 - 01:55:33 PM »
Yes vins match: JS29N0B
Offline Jshort
« Reply #3 on: November 30, 2014 - 02:01:28 PM »
Original 383 is gone with a 70 440 in its place which is fine with me, doesn't have to be completely original but would like it to have a vinyl top, just can't figure out if you could order that combination without black top, if not then the whole car could be a total clone.
Offline Cuda Cody
  • Vancouver, WA
« Reply #4 on: November 30, 2014 - 02:08:21 PM »
JS29N0B is a RT/ SE 383.  RT/SE's came with a small window and a vinyl top.   Someone might have removed it at some point in the cars 40+ year life.  Now those SE parts are hard to find and expensive.
Offline anlauto
« Reply #5 on: November 30, 2014 - 02:08:39 PM »
NO...You could not get a RT/SE without the small rear window and vinyl top. It was a part of the package and NOT an option  :2cents:
Offline rUNCHARGER
« Reply #6 on: November 30, 2014 - 02:21:13 PM »
Check to see if the numbers on the rad support and cowl match the VIN on the dash and title.
Sheldon
Offline Jshort
« Reply #7 on: November 30, 2014 - 02:22:23 PM »
Thanks so much, now the hard part, how do it get a large window without extensive body work? Also should it be put back to just an RT with painted top and vin tags indicating SE.
Offline Jshort
« Reply #8 on: November 30, 2014 - 02:23:32 PM »
Rad support and cowl match
Offline Jshort
« Reply #9 on: November 30, 2014 - 02:26:51 PM »
Car looks good the way it is but now me and anyone else who knows about these cars will think it's not a true RT/SE🚏🇮🇹😔
Offline anlauto
« Reply #10 on: November 30, 2014 - 02:27:27 PM »
The small SE window is just a fibreglass plug that fits into the large rear window frame.
Offline 750-h2
« Reply #11 on: November 30, 2014 - 02:44:50 PM »
I believe the headliner on the SE is also completely different . If you decide to make the conversion I have a spare SE fiberglass plug and glass [no trim]. I live in Canada so shipping would be expensive.
Found this one on Ebay [not mine] http://www.ebay.com/itm/1970-challenger-SE-rear-window-/331398210376?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4d28df6348&vxp=mtr
« Last Edit: November 30, 2014 - 02:51:20 PM by 750-h2 »
Offline Jshort
« Reply #12 on: November 30, 2014 - 02:52:52 PM »
Not sure about the mounting hardware, must have been changed but if it's possible to change back I'm not too far from Canada!
Offline 750-h2
« Reply #13 on: November 30, 2014 - 03:16:44 PM »
Not sure what was done to convert yours to a non SE roof, but I can tell you what you would need to install an SE window on a regular Challenger.
Outside:
-SE fiberglass rear window plug
-SE rear glass
-SE window trim
-wide seam vinyl top
-SE stainless trim for vinyl top
-SE roof badges
Interior:
-SE [rigid cardboard] headliner
-SE sail panels
-SE plastic surround for rear window
-Roof console.
« Last Edit: November 30, 2014 - 03:29:21 PM by 750-h2 »
Offline Jshort
« Reply #14 on: November 30, 2014 - 03:28:51 PM »
Thank you all for the help, it has the original roof console, the interior is black with wrong color headliner seats are black vinyl with leather middle not sure if seats are original, also need to know how do you attach the trim if there's nothing around window?
