Author Topic: 1970 A66 Challenger 340 - Resto Mod  (Read 21175 times)
Offline AussieMark
Re: 1970 A66 Challenger 340 - Resto Mod
« Reply #45 on: March 04, 2015 - 04:02:44 AM »
We ran the beast, only to find the driver side cylinder head is leaking coolant.
not sure where to get replacement heads, many vendors.
any advice? When you say leaking coolant where is it coming from?, it could just be a bad head gasket and what about the exhaust manifold bolt holes do some of them go to water? maybe remove the head and have it pressure or crack tested to confirm and then just look for a replacement on Ebay or Craig's list sometimes you can pick up a pair cheap.
Offline salyaqout
« Reply #46 on: March 04, 2015 - 09:00:31 PM »
Here is the first turnkey.
That's when we found out the head was shot.
The car was only on headers,  Enjoy!
« Last Edit: March 04, 2015 - 09:06:37 PM by salyaqout »
Offline dougs bs23
« Reply #47 on: March 04, 2015 - 09:29:55 PM »
Did I read right, Kuwait for paint?  For heads. Check all the local vineyards for 360 heads. Between Hagerstown to the shore ,Winchester to Norfolk you should be able to locate some
Offline salyaqout
« Reply #48 on: March 04, 2015 - 09:32:36 PM »
Yes sir,  I am originally from Kuwait.  A full paint job will set you back $2000 in kuwait. Show quality.
What about this?
Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=171694318883&alt=web
Offline salyaqout
« Reply #49 on: March 06, 2015 - 12:58:42 PM »
Newest updates!
Ordered  these parts to be installed :
Mopar performance Alu.  Heads with upgraded valves 2.02
Edelbrock Air gap intake manifold
Cloyes timing set
This should bring that small Block back to life.
Offline salyaqout
« Reply #50 on: March 12, 2015 - 04:46:11 PM »
All parts arrived,  should take a couple of days for the cat to purr.
« Reply #51 on: March 12, 2015 - 04:51:07 PM »
Please get rid of that plastic fuel filter.  That's a fire waiting to happen. :2cents:  Only run very short chunks of rubber fuel line.
Offline salyaqout
« Reply #52 on: March 12, 2015 - 04:52:36 PM »
It came with edelbrock setup as a recommendation,  are you sure?
« Reply #53 on: March 12, 2015 - 04:54:29 PM »
Put a metal filter on it and run more metal line up to the carb.  Minimize the amount of rubber hose in the system.
Offline salyaqout
« Reply #54 on: March 12, 2015 - 04:55:40 PM »
Do you mind putting a link for suck setup?
I need to order parts in that case.
« Reply #55 on: March 12, 2015 - 05:01:53 PM »
You can see that the factory used a metal filter and short 2" pieces of rubber hose on either side.  Then, another metal line was used up to the carb.  Rubber lines can dry out and crack.  Metal lines and filters are safer.
http://mmcdetroit.com/ICCA/References/Engine_Compartment/image_78.html
http://mmcdetroit.com/ICCA/References/Engine_Compartment/image_77.html
You'll just need a generic fuel filter and a straight piece of 5/16" fuel line.  You can bend it to go where you need it to.
Generic filter like this...
http://www.summitracing.com/parts/wix-33031/overview/
« Last Edit: March 12, 2015 - 05:05:25 PM by burdar »
Offline salyaqout
« Reply #56 on: March 18, 2015 - 11:53:39 AM »
Heads and intake removed.
Decided to swap Cam,  rockers a push rods.
After a conversation with comp cams,  I decided to go with:
Their CL20-210-2 cams with 260/260 duration and 440/440 lift.  Also got their rockers and push rods.
Offline AussieMark
« Reply #57 on: March 19, 2015 - 09:11:57 AM »
Can you show a photo of where the water was leaking from the head?
Offline salyaqout
« Reply #58 on: March 24, 2015 - 10:20:28 PM »
This is the crack, it goes all the way through. My tech says it could have been fixed at a time before.
free screen capture software
windows screen capture
Offline salyaqout
« Reply #59 on: March 24, 2015 - 10:23:19 PM »
Heads and Cam are on.
Also, timing chain and gears have been replaced.
