Author Topic: Pre Bent Fuel Line Installation  (Read 837 times)
Offline 74Cuda318
« on: December 05, 2014 - 11:46:15 PM »
I'm installing pre-bent fuel lines on a 74 Cuda 318.  It was a long time ago that I removed the original lines and I can't seem to find pics if I even took any.  There is a small line and a larger line that run together on the passenger side.  Which line runs on top of the other along the frame rail in the rear wheel housing area?  I'm trying to determine if the lines are not bent quite right or if I'm not installing it correctly.  Any photos of the fuel line routing on 72-74 Barracudas?
Re: Pre Bent Fuel Line Installation
« Reply #1 on: December 06, 2014 - 09:35:36 AM »
Offline 74Cuda318
« Reply #2 on: December 06, 2014 - 06:06:57 PM »
Thank you, Bullitt.  I'm going to try to get it done tomorrow.
