Author Topic: K Member causing vibrations: Need old posts  (Read 1747 times)
Offline DocMel
« on: December 06, 2014 - 05:33:32 PM »
There are some older posts regarding vibrations at certian speeds caused by the K member:
If possible, if you had a K member related vibration problem, please let me know how you found out it was your K member causing the prob, and what you did to fix it.
Thanks
Offline sadil340
Re: K Member causing vibrations: Need old posts
« Reply #1 on: December 07, 2014 - 10:23:01 AM »
This isn't exactly what you're looking for but my motor was sitting crooked on the K-member. I loosened all engine/trans mount bolts and jimmied the engine around till it was straight. It helped a lot.
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
« Reply #2 on: December 07, 2014 - 10:31:13 AM »
Straight in relation to what? Not trying to sound like a smartass, just curious what you used for reference points to determine straight.
Offline DocMel
« Reply #3 on: December 07, 2014 - 02:29:48 PM »
Good point  WHat ref did you use?
Offline sadil340
« Reply #4 on: December 08, 2014 - 03:30:10 PM »
I saw this done on Graveyard Carz (although I hate to admit it) but Worman spotted that the engine in their winged car restoration was crooked by sighting the oil pan in relation to the K-member. I just moved the engine until the pan was parallel with the plane of the K-member.
3:55 SureGrip
Owned since 1974
Offline shadango
« Reply #5 on: December 23, 2014 - 02:31:27 PM »
I assume that if the k member were the issue, the vibration would be when rolling /tranny engaged versus just sitting in neutral, yeah?
Offline ShelbyDogg
« Reply #6 on: December 23, 2014 - 07:39:43 PM »
If the driveline is straight then then only angles that change are the up and down angles of the pinion and the trans yoke. If not, then there is a compound angle that would throw some vibrations into the mix.
I have a strange resonating vibration around 80 that is still there when I push in my clutch, eliminating the engine. I've also changed out all of my wheels and tires. Its like on for a second, off for a second, on for a second, etc.
I'm thinking that I need to do an alignment check with the mains all the way to the rear-end yoke's center to see if they line up. I've been to Jerry Bickel's and Jerry Haas's race cars shops in the early 90s , when I used to drag race and I noticed that when they lined up the engine and rear end, they would use a solid bar, bolted to the mains, that went all the way to the rear end to center everything up.
I might try to use some kind of laser to shoot a beam to somehow check alignment. Maybe hang some plumb bobs from the crank front snout, then the trans' output shaft to see if they point straight to the rear end's yoke.  My car was in a left front wreck sometime in it's life causing me to change my left front frame rail, when I restored it. I should have taken it to a frame shop to have it all laser aligned before paint.
 If anyone knows of how others have checked this let me know.
