Author Topic: 70 Challenger Conv. Resto Mod-6.1 Hemi  (Read 60511 times)
Offline anlauto
Offline soundcontrol
Re: 70 Challenger Conv. Resto Mod
« Reply #16 on: January 31, 2015 - 03:26:48 PM »
Yeah, I though I could get by without a tool, and they are not available in Sweden what I can see, gonna go to the hardware store tomorrow and se if I can get some clamps of some kind and make a tool.
/ Ken
topic=108917.new#new
Offline CudamanTom
« Reply #17 on: January 31, 2015 - 03:34:19 PM »
I hope your replacing the T-bars.
Never mind. I see you have them on your list of parts you purchased.
« Last Edit: January 31, 2015 - 03:36:10 PM by CudamanTom »
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline drewcrane
« Reply #18 on: January 31, 2015 - 03:36:25 PM »
Use a piece of wood and hammer ,and knock the whole LCA back and it will come apart
Offline anlauto
« Reply #19 on: January 31, 2015 - 04:53:20 PM »
Undo the upper control arms from the spindle. Support the K frame with a floor jack. Remove the four K frame bolts and then pound the K Frame forward off of the torsion bars.
Nevermind..
If you're replacing the torsion bars, then just cut the darn things...
« Reply #20 on: January 31, 2015 - 06:32:46 PM »
I guess I have to remove the strut rods also, so the LCA goes further back, didnt do that yet, I got the LCA about 1/2-3/4" back but that was not enough to move the T-bar. Dont wanna cut them, want to keep all my stock parts. I'll try again soon.
/ Ken
Offline drewcrane
« Reply #21 on: January 31, 2015 - 06:54:40 PM »
Yes remove the strut rods , they should come out with some effort
« Reply #22 on: February 01, 2015 - 05:18:39 PM »
Success today. Got the T-bars out. Started out trying to make a clamp that I could hit with a hammer, no go... need a much heavier clamp than my lame one, see pict. 1. Next I removed the strut rod and then I could hit the LCA even further back, and that did it. On the drivers side it was easier, did not even have to remove the strut rod there.
UCAs, 3 of the adjustment bolt came out fine, the forth was stuck, seem to have rusted in the bushing so I had to use a lot of hammering and prying to get it out, bushing was trash. Only thing left now before I lift the car is to loosen the steering column. Floor jack fitted nice under my K-frame stand. Anyone knows what size the K-frame bolts are? (Need to get a new socket, my largest one is 1").
« Last Edit: February 01, 2015 - 06:19:00 PM by soundcontrol »
/ Ken
« Reply #23 on: February 01, 2015 - 05:24:03 PM »
My rear transmission mount, is the shifter support bracket originally mounted to the transmission mont like this? This is my first small block Mopar and I dont remember my big block cars having the bracket there. Think it was monuted on the transmission. And what is the extra bracket facing forward on the tranny mount?
/ Ken
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #24 on: February 01, 2015 - 05:45:29 PM »
It is mounted on the tailshaft .Some transmission tailshafts don't have the bosses that is why someone welded it to the crossmember.
« Reply #25 on: February 01, 2015 - 06:21:18 PM »
Aha, the car probably had a 904 originally (G-code) so someone put this 727 in with the 340.
/ Ken
« Reply #26 on: February 05, 2015 - 10:36:57 AM »
Anyone knows the size (socketsize) of the K-frame bolts? I need to go get a socket for those.
/ Ken
Offline roadman5312
« Reply #27 on: February 05, 2015 - 10:42:13 AM »
1 1/16 inch
« Reply #28 on: February 05, 2015 - 10:48:35 AM »
/ Ken
« Reply #29 on: February 08, 2015 - 07:06:18 PM »
Tried to lift today, close, but no cigar. The engine hoist only went half way up, been leaking oil. Get more oil and a new try tomorow!
/ Ken
