Yes the carb plate will work but make sure the manifold bolts are all in and tight. Also the carb bolts/studs need to be replaced with grade 8 bolts the proper length and tightened. If in doubt, use a load leveler device or a lifting chain bolted to opposite corners. Better to be safe so use whichever method you are most comfortable with.
