Author Topic: Master Brake Cylinder Alternatives  (Read 580 times)
Offline boxfox
« on: December 12, 2014 - 02:58:36 PM »
I have a brake master cylinder that is leaking so I'm guessing that I am now in the market for a new one. Is it best to just go with one of the old 50 pound cast iron units or are there any good or worth it alternatives?
Re: Master Brake Cylinder Alternatives
« Reply #1 on: December 12, 2014 - 09:02:24 PM »
With an adapter plate you can use the later Mopar alum master with the plastic reservoir
Offline sassygreen
« Reply #2 on: December 13, 2014 - 01:31:11 PM »
Make sure you get the correct piston size or braking will be affected.
Offline jhaag
« Reply #3 on: December 13, 2014 - 06:27:54 PM »
look on dr. diff website. he has a good deal on the later model aluminum master with the adapter, and will get you the correct piston size.
love 70 Challengers
