Author Topic: Small engine parts  (Read 1330 times)
Small engine parts
« on: December 13, 2014 - 10:22:09 AM »
In my very slow gathering of parts for an engine rebuild, I was thinking about ordering rings, bearings, and a crank. Who makes a good bearing or a good ring? Are there companies to stay away from?
Clevite comes up for bearings a lot
Speed pro seems popular for rings.
Any recommendations?
Offline jhaag
Re: Small engine parts
« Reply #1 on: December 13, 2014 - 06:24:18 PM »
that's exactly what I would use
love 70 Challengers
Offline jimynick
« Reply #2 on: December 13, 2014 - 06:39:30 PM »
ACL- (supposedly Australian Clevite) and Federal Mogul and Pioneer are some others bearingswise. Grant, Hastings, SRP, Perfect Circle, Mahle have all been around the ring biz a long time and many are and/or were, oem suppliers. I've got to figure out a way to get that timing set to you. They changed my job and it's no more trips to TB!  :stomp:
« Reply #3 on: December 13, 2014 - 06:41:52 PM »
Make Sure you use a plasma moly ring set , chrome will not break in within your lifetime !
« Reply #4 on: December 14, 2014 - 04:09:29 PM »
Thanks for the replies. :cheers: And I'll stay away from chrome.
« Reply #5 on: December 14, 2014 - 04:12:15 PM »
One other question. Satndard tension rings? Low tension rings? What are the different tensions for?
Offline jhaag
« Reply #6 on: December 14, 2014 - 07:21:24 PM »
standard tension replacement ring sets. low tension are for race engines to reduce rotating friction. they would only cause you heartache in a street engine.
love 70 Challengers
Offline cudabob496
« Reply #7 on: December 14, 2014 - 08:26:32 PM »
the thickness of the ring matters too, I think?
I used thinner rings on my 496.
2011 Kawasaki Z1000
Offline jimynick
« Reply #8 on: December 14, 2014 - 10:24:49 PM »
The ring size will be predicated by the piston used. Old school were usually 5/64", but you now see 1/16", .043 and 1.5mm quite often.
