Author Topic: Looking to do some performance mods  (Read 6906 times)
Offline stinger
« on: December 13, 2014 - 02:54:17 PM »
I wish I had built my 440 myself but time and money at the time made that a dream but the car runs fairly strong for what it is and it's just a street car. that being said anyone have some reasonable performance mods for my car?
70 Barracuda
71 440,steel crank .030 over,sp 2266 pistons that I measured .070 down :clueless: not sure how that is??? cut down 452's,full port job,2.14 1.81 valves cc'd 85cc's. lunati 303 cam 226/234 .494/.513, comp 911 springs,stamp rockers,steel head gaskets,165 psi cranking pressure,13/4" headers full magna exhaust with x pipe,melling HV oil pump, firecore dist,wires,cd coil,msd 6a box chained to the K.performer rpm intake,eddy mech. fuel pump, Holley 850 dp with stock jetting and all plugs are a light grey/tan.
727 with 10" 2800 converter CRT man/auto VB,3:91 83/4 ,cooper 275/40 r17 tires with American racing wheels. frame ties,ss springs and 1" lowering blocks.
I think my hands are tied with the pistons but would like to keep improving with what I have if it's worth it and some day I might be able to build a better engine.who knows?
Offline cudabob496
Re: Looking to do some performance mods
« Reply #1 on: December 13, 2014 - 04:48:41 PM »
what is your CR, and what do the heads flow?
I'd lean towards 1 and 7/8 headers. I had used Hooker Super Comps on
my 440.
« Last Edit: December 13, 2014 - 04:50:42 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #2 on: December 13, 2014 - 07:08:49 PM »
Those pistons are slightly lower compression so that hurts you & it limits cam lift with no valve reliefs , but pulling down the engine & replacing pistons is major + rebalancing . You could stroke it if you go that far & get over 500 CI .
The heads are limiting as well , the port work could be poor to great so that is a variable , also you have no quench as the piston will be a long way away from the heads so it can be a detonating problem as well .
 Alum heads will hurts as you lose even more compression heat , but the flow would help at higher RPM .
 More cam lift could get close the pistons , + you have decent cranking pressure already
Offline cudabob496
« Reply #3 on: December 14, 2014 - 09:40:13 AM »
I think if lower compression ratio, you may be able to compensate
somewhat by using a shorter duration cam.  But still, top end power
will be hurt. If low compression ratio and a longer duration cam, you will
defintely be losing power.
Also, I think you can compensate somewhat for aluminum heads
keeping cylinder pressure down, by running a hotter thermostat.
2011 Kawasaki Z1000
Offline stinger
« Reply #4 on: December 14, 2014 - 08:16:54 PM »
these were all my thoughts as well. just wondering if things like adjustable rockers or a pro form carb body would add some more performance. on the other hand the car runs good as it is so why mess with it.
« Reply #5 on: December 14, 2014 - 08:38:11 PM »
Adjustable rockers will make the cam lift & duration more accurate but could be all that is keeping the valves from hitting the pistons right now .
 proform body could make the carb more responsive but the Holley carb is good so you might gain a little
Offline jhaag
« Reply #6 on: December 14, 2014 - 10:29:20 PM »
stinger, you have a pretty highly modified combination for driver currently. I would maximize the tune and run it as is. you will get a million opinions asking an open ended question like you did. your gains would be minimal, and options few, unless you are willing to do a complete rebuild and spend many $$$.
love 70 Challengers
Offline stinger
« Reply #7 on: December 14, 2014 - 10:45:16 PM »
yes jhaag I agree,just having to much fun optimizing what I have and want to keep going.I'm one of those that likes to work on them more then driving. I asked the open ended question just to see other opinion's but most points I've already considered. my car so far has been very reliable,strong running and  fun to drive so I suppose I'll turn my attention to other upgrades.
Offline RCCDrew
« Reply #8 on: December 15, 2014 - 08:38:30 AM »
One option would be to mill the heads. I think the general consensus is that the low compression is limiting you.
Offline cudabob496
« Reply #9 on: December 15, 2014 - 08:41:25 AM »
cold air intake can get you 25+ hp.
1.5% power increase for every 10 degrees you lower carb
inlet air temp.
www.ramairbox.com
http://www.ramairbox.com/install.html
« Last Edit: December 15, 2014 - 11:40:50 AM by cudabob496 »
2011 Kawasaki Z1000
Offline stinger
« Reply #10 on: December 15, 2014 - 07:33:46 PM »
I recently read some threads on another site where a 9:1 440 with aluminum heads made 650 horse. my car will put a smack down on a buddy's 10:1 427 vette so it's not slow,neither is the vette. I just have fun doing the little mods.
inlet air temp.
www.ramairbox.com
I was considering something like ram air. I don't want to cut the car up for it though and don't care for an aar hood or the price on a shaker. I do like the set up on the dart but wonder if it would work on my car.
Offline cudabob496
« Reply #11 on: December 15, 2014 - 08:43:09 PM »
works great on mine:
2011 Kawasaki Z1000
« Reply #12 on: December 15, 2014 - 08:49:46 PM »
If you wer to swap heads I would look at the new Twisted flow heads or the stealth as they have 70 cc chambers & will make up for the heat lost to alum + you gain the closed chamber , if you are down to 85 cc now the heads are milled about as far as you could go
Offline stinger
« Reply #13 on: December 15, 2014 - 09:58:55 PM »
I know all to well how good ram air works as my set up back in the day I ran an aar hood sealed to the air box and noticed a big difference. If I could do it without cutting my car up I would but I spent way to many hours on the body to cut into it.
It is cheap horsepower though  .
Yes I've been keeping my eye on the twisties, they look to flow real well on lower lifts and drop some weight.
Offline Road_Runner
« Reply #14 on: December 16, 2014 - 09:40:53 AM »
I'm going to run a little steeper gear, either a 4.10 or 4.30 and an overdrive transmission, probably gear vendors.  Definitely help you pull harder with the engine you already have.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
