Author Topic: Carter 2bbl leaking coolant from carb nipple??  (Read 2356 times)
Offline dave73chally
« on: December 13, 2014 - 05:46:12 PM »
Stock carter 2bbl newly rebuilt, coolant is coming out of the nipple below, on the front of the carb. What's happening??? I had low compression in cylinders 6&8 a few months back, heads were warped. That's been fixed, but this is alarming.
73 Challenger
Re: Carter 2bbl leaking coolant from carb nipple??
« Reply #1 on: December 13, 2014 - 06:43:22 PM »
Nothing good for sure !
 The is a vacuum port & is nowhere near a water jacket
« Reply #2 on: December 13, 2014 - 07:32:42 PM »
A/C cars have a gizmo screwed into the intake that vacuum lines run to, think it sensed temperature & redirected vacuum.
...yours have anything like that? ... just a suspicion...
« Reply #3 on: December 13, 2014 - 07:37:18 PM »
Not an A/C car. This motor has been one problem after the next, turning into a real money out ugh. I'll start it back up to sure it's dripping from this port and somewhere else.
73 Challenger
Offline cudabob496
« Reply #4 on: December 14, 2014 - 09:32:30 AM »
does coolant run at all within the intake. If so, maybe a crack in
the intake, or corrosion has opened a pathway for the coolant.
2011 Kawasaki Z1000
« Reply #5 on: December 15, 2014 - 09:15:29 AM »
I'll pull the carb and intake soon and look it over. Is there a certain section I should be focusing on?
73 Challenger
Offline cudabob496
« Reply #6 on: December 15, 2014 - 09:42:04 AM »
or, maybe there's a coolant leak that squirted coolant over to that area,
while the tiny leak itself is a foot or two away.
2011 Kawasaki Z1000
« Reply #7 on: December 15, 2014 - 10:06:54 AM »
What I was thinking....pinhole leak can fool ya.
Offline Road_Runner
« Reply #8 on: December 16, 2014 - 09:31:34 AM »
Some intakes have a hole in the bottom of the plenum under the carb.  If your intake gasket is leaking it could flow through there theoretically I guess but I've never seen it.  Since coolant does flow through small blocks intakes, it could be leaking there.  I'd be doubly sure it wasn't spraying on your carb from the waterneck.  It might be hard to see but a lot more likely than antifreeze coming out of your carb.  Good luck and hang in there.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #9 on: December 16, 2014 - 06:00:36 PM »
the closest coolant is the water passage at the ends on the heads or the crossover where the thermosts is , it would be very unlikely to get from there upstream through the intake & up into the carb base
