Author Topic: How to use a 6.1 from an automatic car?  (Read 5383 times)
Offline chally426
« on: December 14, 2014 - 11:34:55 AM »
First, I am running a 6 speed...So what all is needed to take a motor from an automatic with the MDS and make it all work...
is there a pilot bearing needed...How do you stop the MDS
Offline twoterpilot
Re: How to use a 6.1 from an automatic car?
« Reply #1 on: December 14, 2014 - 08:40:25 PM »
Chally426,
I can't help with the transmission question as I have only used automatics. Too disable the MDS just unplug the MDS solenoids. my self I would pull the solenoids and replace w factory plugs and replace the lifters.
Twoterpilot
Offline chally426
« Reply #2 on: December 15, 2014 - 11:44:56 AM »
Thanks twoterpilot, I'm assuming this would be the same for one of the new 392 6.4 hemi crate motors, most of the ones I see are for Autos, or have the MDS
Offline cjd automotive
    • The Shop
« Reply #3 on: December 15, 2014 - 05:23:46 PM »
6.1's don't have MDS, only 5.7's from 2005 and up in cars and 2006 and up in trucks.  6.4's use MDS, both truck and SRT.
The pilot bearing for a 6.1 is pn# 53009180AB.
BTW, Holley has a plug and play controller and wiring for the GenIII Hemi.  Uses factory sensors.  Call me if you need some info.
« Last Edit: December 15, 2014 - 05:25:54 PM by CJD AUTOMOTIVE »
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
www.STREETANDRACEPERFORMANCE.com
Jacksonville, FL 32220
904-400-1802
Offline chally426
« Reply #4 on: December 15, 2014 - 07:16:55 PM »
Thanks Craig, I will take you up on that, looks like you have done this a few times... What about the 6.4s, Do you really need to disable the MDS? from an auto, I know there are a lot of things needed to activate it like speed sensors, that wont be on an older car?
You wouldn't happen to know a good part number for the 392 6.4 manual crate motor would you, I cant seem to find one anywhere to check pricing from a local dealer.
Thanks
    • The Shop
« Reply #5 on: December 16, 2014 - 09:00:06 AM »
392 crate engines were discontinued.  5.7, 6.1.and 6.9L are what's available now.  Your best bet is a takeout 392 from a Challenger.
Craig Scholl
CJD Automotive, LLC
904-400-1802
Offline Modern Muscle
  • Moderator
    • Modern Muscle Performance Group
« Reply #6 on: January 25, 2015 - 10:27:51 PM »
6.4 are still available I have over 20 in stock.
https://www.modernmuscleperformance.com/product/392-64l-hemi-crate-motor
Offline 73restomod
« Reply #7 on: February 16, 2015 - 06:35:36 PM »
You should manually disable the MSDS by adding the lifter valley plugs. I have some at my house, they are the same for 5.7 and 6.1. These are some fancy aluminum ones, but I'm sure you can find them in the factory plastic variety for far less than 79 bucks.
Just found these for cheap! http://www.highhorseperformance.com/MOPAR_6_1L_MDS_Block_Plug_p/mds-plug.htm
« Last Edit: February 16, 2015 - 06:40:53 PM by 73restomod »
  • Moderator
« Reply #8 on: February 17, 2015 - 12:31:05 PM »
Leaving the MDS solenoids in will not hurt anything, However if you are using an aftermarket cam I would suggest changing the MDS lifters.
Offline soundcontrol
« Reply #9 on: February 17, 2015 - 01:44:27 PM »
How come those 6.4's are pretty affordable at $7895, and I read in other threads that the cost to build a new Hemi is between 20-30K?
/ Ken
topic=108917.new#new
Offline 3D
« Reply #10 on: February 17, 2015 - 06:28:58 PM »
Not for nothing, but if i wax considering changing out the 5.7 Hemi in my 2008 Mega Cab to a 6.4, what would be required?
Offline 73restomod
« Reply #11 on: February 17, 2015 - 07:05:55 PM »
Well the Mopar MSDS block off kit was only 8 bucks, is there any danger to leaving the solenoids in? How different are the lifters from the Non-MSDS motors?
    • The Shop
« Reply #12 on: February 18, 2015 - 06:26:03 PM »
MDS lifter and non MDS lifter.  Dimensionally the same.  See the pin hole and the pin that's halfway showing?  That pin locks the internal lifter bodies together, making it one piece.  When oil pressure is applied through the solenoid, the pin is pushed in and the internal body collapses enough to prevent the valve from opening.  This lifter beat the trunion bearing out, which then beat the snot out of the internal body, turning the internal so the pin would not lock.  So this lifter is in MDS mode forever.  Normally oil pressure from the solenoid is required to UNLOCK the pin, otherwise it stays locked and stays a conventional lifter.
Craig Scholl
CJD Automotive, LLC
904-400-1802
Offline 73restomod
« Reply #13 on: February 20, 2015 - 09:21:22 AM »
Awesome good know the reasons and see the after effects!
  • Moderator
« Reply #14 on: February 20, 2015 - 10:19:10 AM »
If it was a complete forged stroker motor and you have no cores to work with yes those prices are correct.
The 392 Crate Motors we carry are new factory engines from the SRT Line up.
