How to use a 6.1 from an automatic car?
Author Topic: How to use a 6.1 from an automatic car?  (Read 5382 times)
Offline Travis72
Re: How to use a 6.1 from an automatic car?
« Reply #15 on: March 09, 2015 - 06:18:46 PM »
Since no one answer the question about the auto....  The first thing you will need to do is remove the torque converter snout bushing from the back of the crankshaft.  Mine was a pain in the butt to remove.  There are some pictures in my build thread:
http://www.cuda-challenger.com/cc/index.php?topic=28465.285
Yes you will need a pilot bushing.  I think you can use either Timken part number FC69907 or Dodge part number 53009180AB
Travis
72 Cuda
Offline cjd automotive
    • The Shop
« Reply #16 on: March 16, 2015 - 01:27:02 PM »
Travis
72 Cuda
That will bolt it up, but with no VSS signal and aftermarket controllers not yet available, your not going anywhere.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
www.STREETANDRACEPERFORMANCE.com
Jacksonville, FL 32220
904-400-1802
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #17 on: April 04, 2015 - 12:30:37 PM »
He is using a 6-speed so no need for a controller and vss is only needed for a speedo easy solution available.
Especially if it's a t56 magnum  :burnout:
Go Fast & Have Fun...
