Author Topic: Paint crack on windshield pillars, both sides  (Read 3982 times)
Offline dave73chally
« on: December 14, 2014 - 12:38:10 PM »
Noticed the paint is cracking slightly on the windshield pillars right before they meet the roofline. It is on both sides, in the exact same location. How should this be addressed? The paint job is horrible and peeling elsewhere but this seems odd it's in the same spot on both sides. Is it a possibility the body is flexing causing this? See below for location of crack:
73 Challenger
Offline acudadude
Re: Paint crack on windshield pillars, both sides
« Reply #1 on: December 14, 2014 - 01:26:33 PM »
Factory lead in both spots?
Offline rUNCHARGER
« Reply #2 on: December 14, 2014 - 06:45:22 PM »
Factory used lead, but I bet someone put bondo in there hence the cracking.
Sheldon
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: December 14, 2014 - 08:18:24 PM »
There should be very little flexing in that area.  More than likely it is the result of poor bodywork when the car was repaired/repainted before.
« Reply #4 on: December 14, 2014 - 08:28:41 PM »
That's what I'm hoping
73 Challenger
« Reply #5 on: December 14, 2014 - 08:29:17 PM »
Someone posted on moparts that typically cars with vinyl roofs used filler while cars without used lea in this area, is there any truth to that?
73 Challenger
Offline twoterpilot
« Reply #6 on: December 14, 2014 - 08:46:18 PM »
My 74 w the vinyl top had led in that area.
« Reply #7 on: December 14, 2014 - 08:50:53 PM »
Vinyl Top cars did not necessarily get Lead on the front A pillars and sail panels.
I know this for a fact since I owned my car since 1972. It wasn't leaded.
For whatever reason, certain vinyl top cars/years had a wierd type of filler instead of a lead.
« Reply #8 on: December 14, 2014 - 09:02:30 PM »
Mine has cracks there too. No big deal to me? Mine needs a paint job at some point?  :money:
Offline 67vertman
« Reply #9 on: December 14, 2014 - 10:44:55 PM »
My car was a vinyl top car, it had lead in the rear seems and Bondo in the front.
Offline AARTA340
« Reply #10 on: December 14, 2014 - 11:46:53 PM »
Offline rhamson
« Reply #11 on: December 15, 2014 - 08:39:44 AM »
I have had two 1972's that had body filler in that place and the sail panel. Both had been re painted and may have had the lead replaced as body filler will not stick to lead and body shops refuse to deal with it. I have leaded both areas and welded the lower corner where the sail panel meets the rear window. These were a problem with both of the cars. I am hoping that with my frame strengthening efforts and lead filling this will curb this problem. I have seen the cracks appear in cars with as little as six month's after their re spraying with body filler only.
« Reply #12 on: December 15, 2014 - 03:08:07 PM »
Thanks for clarifying guys, always learning something new about these cars  :thumbsup:
A bit off topic, but when the time comes for your repaint, how are you planning on attacking it? Are you doing a full dis-assembly and blasting it?
73 Challenger
« Reply #13 on: December 15, 2014 - 04:16:39 PM »
Hummm no plans yet? The paint doesn't bother me it's good for awhile! Wow it gets painted depends on finances I guess?
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #14 on: December 28, 2014 - 11:30:29 PM »
I've seen some guys us a metal strip welded in these seems to prevent cracking or filler bubbling. I actually used Metal to Metal filler since I stuck on a vinyl top. My car originally had led in both front and rear seams.
E-Body Products
www.ebodyproducts.com
606-481-9014
