Author Topic: Mig Welding Wire and Type  (Read 4310 times)
Offline glovemeister
Re: Mig Welding Wire and Type
« Reply #15 on: December 16, 2014 - 08:49:24 PM »
Sorry about the noob thing, I misread the post. I think Eastwoaod has some copper backing plates for MIG welding body panels. The magnetic ones are nice when you can't reach inside a door or fender. Good luck with the '71 ! :cheers:
No problem on that at all. As far as sheet metal on a 71 Challenger I am a noob at that. Am guessing most of the stuff I have learned is the same lol.
This is like welding x1000 since doing a good job is so important given the car.
Will post up pics as I get rolling. Sure I will be needing more assistance from the pros.
1971 Challenger RT
Offline 734406pk
  • Andy
« Reply #16 on: December 16, 2014 - 09:16:22 PM »
Maybe get any fender from the junk yard to practice on first?
Offline rhamson
« Reply #17 on: December 17, 2014 - 09:05:15 AM »
In my experience of welding sheet metal, MIG has been the preferred method. If you're burning thru, a copper plate and/or machine adjustment will correct this. .023 solid wire with a -6 silicon rating will give the weld puddle more fluid wet out and less grinding. Buy yourself a auto body welding handbook and study up on the process. When you're ready to buy a MIG welder, I would go with a professional unit like a Miller 180 amp with Autoset. Also I have found running the machine on 240 volts gave much better results. TIG is good, but it takes a lot of skill to do at least 3 things at the same time: maintain arc length, control the amperage and probably add filler rod while trying to see. Not easy. Auto darkening helmet is a major plus. Any welding process on sheet metal will cause warpage. A good handbook will show how to minimize the effect. Good luck!
Good advice and has been my experience also. I have a cheap Hobart 185 220V and it can handle just about everything I throw at it in my body work applications.
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #18 on: December 17, 2014 - 12:21:25 PM »
I had a Miller tig unit and sold it cuz it was just too damn difficult.(I wanted to put my car together not learn another vocation) I went back to my mig unit with .030 wire and used stargon gas with it and it worked great. Those copper backer  bars help but can be a pain to get a good contact with the panels.Also like someone earlier said get a 220v unit if possible if not get the highest amp 110v unit
Offline 734406pk
  • Andy
« Reply #19 on: December 17, 2014 - 10:03:07 PM »
Good advice outlaw! Stargon cs works smooth, also C25 (75% argon and 25% C02). I try to use what the wire manufacturer recommends for best results.
