Author Topic: No taipipe/resonator brackets???  (Read 8308 times)
Offline badasscuda
« on: December 17, 2014 - 05:19:22 PM »
1974 Cuda BS23 360 4-speed dual tip car. No brackets, just 2 holes on each side. Out of brackets that day???
Re: No taipipe/resonator brackets???
« Reply #1 on: December 17, 2014 - 08:38:00 PM »
I believe your asking the same question this thread answers
http://www.cuda-challenger.com/cc/index.php?topic=102566.msg1013749#msg1013749
Offline badasscuda
« Reply #2 on: December 17, 2014 - 11:35:43 PM »
Thanks for the reply. I saw that post along with many others and it seems like they at least get the driver side bracket. So I went and looked again
and this is what I found. It has changed a bit since the other pics were taken. I understand the pass bracket. The drivers bracket is for the brake hose.
It has been 15 years so I've forgot most everything by now. I'll have to dig out the old rubber mounts and see what I can piece together.
Either or both of these driver side holes for a mount and what should it look like.
« Last Edit: December 18, 2014 - 12:17:36 AM by badasscuda »
« Reply #3 on: December 18, 2014 - 07:53:28 AM »
In this photo on the far right is a plate with 4-studs that the drivers side bracket mount to.(see next post)
The two sets of holes closer in on either side of the tunnel are for course thread bolts to secure the back seat. http://www.cuda-challenger.com/cc/index.php?topic=95200.msg935636#msg935636
In this photo the arrow on the left points to the holes the passenger side hanger bolts to. Install two J-juts... item on right is where brake line bracket bolts.
J-nuts avail many places, I picked some up at Tractor Supply
« Last Edit: December 18, 2014 - 08:18:40 AM by Bullitt- »
« Reply #4 on: December 18, 2014 - 08:10:47 AM »
that drivers side should have 4-studs for nuts...realized this reviewing my own resto work..
   ( I'm not using stock hangers but you can see the nuts holding the bracket)
Here you can see the studs, I suspect yours were broken off & burred under undercoat
« Last Edit: December 18, 2014 - 08:21:45 AM by Bullitt- »
Offline 4 speed fish
« Reply #5 on: December 18, 2014 - 11:41:45 AM »
You can buy the correct bracket on Ebay.
Offline badasscuda
« Reply #6 on: December 18, 2014 - 02:19:02 PM »
OK. Thanks for the pics. I thought there was a backup bracket inside the car.
I did see the bracket on ebay and elsewhere. Thanks.
Offline 7212Mopar
« Reply #7 on: December 19, 2014 - 12:34:57 AM »
I removed my exhaust system today. There is no studs at the driver side. Are the studs through the sheet metal and then welded? Will I see evidence of it at one time if I pull the rear seat? The passenger side has the same mounting point like the picture. My car is a 73 Rallye with factory dual exhaust. It had a replacement exhaust put in at one time and was not using the factory support points. I will be replacing with a TTI system down the line.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
« Reply #8 on: December 19, 2014 - 08:13:41 AM »
plate mounts inside with 4-studs protruding to underside.   R/T specialties sells both pieces together it appears
http://www.rtspecialties.net/proddetail.asp?prod=1705014
Offline anlauto
« Reply #9 on: December 19, 2014 - 09:06:41 AM »
Bullitt's picture shows the bracket that bolts to the DRIVER'S side. (one plate inside with studs, one plate outside with nuts) There is a similar looking plate that welds onto the floor on the PASSENGER side. This was standard on all 1970-71, possibly 72's. By 1973, 1974, they did not have the passenger side one welded to the floor, they used a loop type mount bolted to the shock cross member :2cents:
To mount your TTI system you'll need both floor brackets. :burnout:
Offline 7212Mopar
« Reply #10 on: December 19, 2014 - 06:49:51 PM »
Will the brackets come with template for drilling? Anyone has dimensions?
Offline badasscuda
« Reply #11 on: January 03, 2015 - 05:46:18 PM »
So I looked for my exhaust mounts and look what I found. The correct driver side dual exhaust mount.
Mounts in the two holes I previously pointed out. Soaking in rust remover right now. Tomorrow I will
see if I can find some part numbers.
Offline CUDA JAS
  • vroooooom!
« Reply #12 on: January 07, 2015 - 02:37:11 PM »
Not sure if they come with a template for drilling or welding, but Accurate has the driver side (bolt on).  I think there are dimples on the floor for the drivers side.
Goodmark has the passenger side (weld on)...good price too!
https://www.goodmarkindustries.com/p-7097-bracket-exhaust-pipe-hanger-70-71-e-for-muffler-hanger-2120-517-707.aspx
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline shawge
  • Zoiks!!
« Reply #13 on: January 07, 2015 - 03:22:46 PM »
There should be dimples.  I recently added the driver side bolt on bracket to my car w/ original sheet metal.  Not sure if the aftermarket panels have the dimples.
- Jerry
Offline badasscuda
« Reply #14 on: January 12, 2015 - 10:33:38 PM »
Found the rest of the brackets today. Good thing I didn't drill holes in my floors.
And here is the underneath of an original '74 for reference.
