Author Topic: No taipipe/resonator brackets???  (Read 8309 times)
Offline CUDA JAS
  • vroooooom!
Re: No taipipe/resonator brackets???
« Reply #15 on: December 10, 2015 - 11:56:48 AM »
So are  you saying the 74's used the hanger bolted to the shock cross member on both sides?
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline anlauto
« Reply #16 on: December 10, 2015 - 12:22:14 PM »
Yes he is...a unique feature of 1974 only. :2cents:
Offline CUDA JAS
  • vroooooom!
« Reply #17 on: December 10, 2015 - 12:24:45 PM »
well hell.
If a car had single exhaust would the mounting provisions for dual exhaust be on the cross member of would the cross member be different?
Jason
74 'cuda 360/727
Offline anlauto
« Reply #18 on: December 10, 2015 - 12:26:01 PM »
I would say the cross member would be the same :2cents:
Offline CUDA JAS
  • vroooooom!
« Reply #19 on: December 10, 2015 - 12:48:38 PM »
I guess I will jack up the car tonight and see what I can find.
I guess that explains why I do not have the recesses or the dimples in the floors for the early style brackets.
I really wish I had know this before I bought two hangers for the early style brackets at moparfest!! :banghead: :banghead: :banghead:
Oh well.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #20 on: December 10, 2015 - 12:56:15 PM »
You'll see a flat portion in the floor where the brackets will go.....except of course, if the 74 has a different floor pan too... :smilielol:
Offline CUDA JAS
  • vroooooom!
« Reply #21 on: December 10, 2015 - 10:55:37 PM »
Ok...looks like I have the provisions for both hangers on the crossmember.
Passenger side, used for single exhaust.
Driver side, looks to have both holes, the second bolt hole is already in use for the exhaust hanger:
So I guess I need to look for the correct brackets and probably fab up the mounts for the driver side, I am sure that piece is not repoped.
I think I see the flat portion on both sides of the floor, but no dimples,  so I guess I could mount the early style brackets, but I am not sure.
Jason
74 'cuda 360/727
Offline badasscuda
« Reply #22 on: February 16, 2016 - 12:40:14 AM »
update: I was able to install my 2 1/2" exhaust using the original mounting brackets.
I did have to make new clamps to go around the bigger exhaust, but I shaped them to
look exactly like the originals. Fits like it should.
And a factory drawing of the 1974 360 dual exhaust.
