Author Topic: Customizing a non-rally dash for aftermarket gauges  (Read 20435 times)
Offline dutch
Re: Customizing a non-rally dash for aftermarket gauges
« Reply #15 on: January 05, 2015 - 05:37:35 PM »
looking good  :2thumbs:  I`d love to see it all installed...should be nice & clean   :bigshades:
*** Bart ***
Offline Mickm
« Reply #16 on: January 07, 2015 - 05:18:49 PM »
Ok, I just received my abs printed gauge sleeves. :crazy:
These are .100" thick with a lip for mounting the gauge and a lip to match up with the oem abs plastic dash.
This is a isometric view of one of the four smaller gauges.
Here it is lightened in photoshop to give a more accurate visual representation of the part.
Here's a side view of the same sleeve.
Here is the smaller gauge installed.
This is the speedo/tach in its sleeve.
The gauges fit so well they simply click into position and the SpeedHut securing ring tightens down very nicely. Initally, I am very pleased :ylsuper:
If you look closely you can notice a continuation of small flat faces around the sleeve which I did not put into the design but the printer added. In person they actually look pretty cool and add somewhat of an oem flavor.
Next I will trim the oem gauge panel to the desired depth and fit the sleeves. I'll post pics when that is done but I was excited as the looks of the printed parts and wanted to share.
Cheers!
Mickm
« Last Edit: January 07, 2015 - 05:25:24 PM by Mickm »
MickM
Offline ToxicWolf
« Reply #17 on: January 07, 2015 - 05:26:45 PM »
Looks great.   :woohoo:
Offline dutch
« Reply #18 on: January 07, 2015 - 06:10:09 PM »
sweet!   I really like the way the surface looks.  Very different from lathe work.  :2thumbs:
*** Bart ***
Offline Mickm
« Reply #19 on: January 12, 2015 - 02:46:19 PM »
I thought I would share a  pic of the first gauge I have mounted in the oem panel with the abs printed sleeves.
I had to lighted the photo just a tad as it was too black otherwise.
Here's what it will look like from the back.
I will post the entire panel once I have completed it. Hopefully, by the end of the week.
Thanks,
Mickm
MickM
Offline ToxicWolf
« Reply #20 on: January 12, 2015 - 03:24:23 PM »
Looks great. Keep 'em coming.   :2thumbs:
« Reply #21 on: January 12, 2015 - 03:45:36 PM »
Looks great. You could paint the raised bit silver like stock.  :2thumbs:
Offline Mickm
« Reply #22 on: January 14, 2015 - 02:32:43 PM »
I finished installing the gauge sleeves today.
I had to trim the oem sleeve twice. The first time there was a small portion of the "half moon" opening at the bottom and it did not look right so I trimmed it back to the tangent edge of the eclipse.
I will have to take the temp and gas gas out of the car to put in this panel to show how it looks with all the gauges. I'l try to do that tonight and show the finished product tomorrow.
I think it is looking pretty good thus far. What do you think?
Cheers!
Mickm
MickM
Offline ToxicWolf
« Reply #23 on: January 14, 2015 - 07:03:57 PM »
Looks fantastic.   :clapping:
« Reply #24 on: January 14, 2015 - 07:30:59 PM »
Looks great!  :2thumbs:
Offline soundcontrol
« Reply #25 on: January 15, 2015 - 06:37:44 AM »
Very nice! What did it cost to print the sleeves? Are the quality of the plastic good? Is it a harder plastic or can it bend some?
/ Ken
topic=108917.new#new
Offline Mickm
« Reply #26 on: January 15, 2015 - 09:32:09 AM »
Thanks for the kind words Wolf and Brad :ylsuper:
soundcontrol, The company I work for is a member of SEMA and therefore we can get parts printed thru them. I am told all we pay is material cost.
It cost me $120 for the 5 sleeves. I simply made the 3d models, saved as .stl. files and emailed to them. About a week later the parts showed up. They are .10" thick and thus very rigid. After I cut the sleeves off the oem panel I was faced with the overhang of my sleeves being held off by the fillet at the base of the oem sleeve at the dash. I simply chucked my abs sleeves up in my lathe and turned down a internal chamfer that allowed my sleeves to fit perfectly atop this fillet.
I did not try but I do not believe you could bend the printed sleeves.
As for the quality of the printed sleeves. I would say it is excellent! I want to give credit where credit is due, going this route was initially ToxicWolf's idea. I was going to make the sleeves from fiberglass. I am confident Wolf's idea was by far the better approach.
I will share something I learned during this process in case anyone wants to use this approach. I did some research as to the best method of attaching/gluing my sleeves to the oem abs dash. I found out the best approach is to use the material from the oem sleeve that I cut off. Trim it into very tiny pieces, place in a plastic paint cup and cover with acetone. The acetone will dissolve the tiny abs pieces whereby making a thin paste. I laid the oem dash on my work bench (face down), placed the printed abs sleeves in place and secured with a metal bar secured by an set of eagle beak pliers. Then you simply brush on the acetone/plastic paste where the two join and in a matter of a few minutes, they are secured. The acetone/plastic paste works like a plastic welds and actually fuses the two pieces together rather than just gluing them. I though this was very cool. It worked perfectly and did not leave any residue on the front of the gauge panel. :2thumbs:
I had to work very late so I did not get out in the garage last night to remove the two remaining gauges but I should be able to tonight. Pictures tomorrow hopefully.
Cheers!
Mickm
« Last Edit: January 15, 2015 - 12:09:13 PM by Mickm »
MickM
Offline Mickm
« Reply #27 on: January 15, 2015 - 02:06:27 PM »
I have been asked to post a pic of the dash with the gauges I have out of the car so they could see what the sleeve looks like with and without the gauge.
So here are a couple
Here's the front from a somewhat headon view
Here's a view from the back. If you notice the area where I painted the plastic mixture looks almost exactly like the original. Maybe they used the same method back in the day???
My plan is to paint the original ring's outter face silver and apply a carbon fiber overlay.
Cheers!
Mickm
MickM
Offline crash340
« Reply #28 on: January 15, 2015 - 03:57:42 PM »
That is all looking really, really good, love the idea, as the factory facia is only a cosmetic cover, will the mounting points be strong enough to support it correctly without lossing shape or breaking the tabs once the gauges are in place etc, or are you planning on using the alloy gauge housing to support it somehow?
Greg
73 Cuda
Brisbane, Australia
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #29 on: January 15, 2015 - 06:20:35 PM »
Looks awesome man!  How much to print me a set?   :2thumbs:
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
