I made a hidden antenna for my cuda because of the tilt front end, I didn't want the antenna wire stringing across when the hood was up. If you remember the old antenna that was embedded in the top of the winshield, I made one that I tucked under the trim piece on the inside of the glass. Turns out to work better than the original ever did. I took an old house stereo antenna that goes on the wall (looked like a cheezy wire "T" and came with about all cheap stereos -I think they were called a dipole antenna ) and cut an old car radio antenna and soldered them together and wrapped with tape the plugged in to radio and tucked it under trim and it works great -picks up more stations then I knew were available.
