Author Topic: What is VVT exactly and is it ok in a resto mod  (Read 4581 times)
Offline chally426
« on: December 19, 2014 - 06:35:06 PM »
Looking at a 6.4 that says "has VVT", I know it is variable valve timing, but is this on all 6.4's and is it o.k. for a resto-mode application
or is it the same as MDS..??
Thanks
Offline 7212Mopar
Re: What is VVT exactly and is it ok in a resto mod
« Reply #1 on: December 19, 2014 - 07:53:05 PM »
See Allpar
http://www.allpar.com/mopar/SRT-V8.html
No one care for MDS but VVT and long and short runners you might want to retain. Give Arrington a call.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline jimynick
« Reply #2 on: December 19, 2014 - 08:06:07 PM »
V V T is a power and emissions play used on all cylinders; MDs or displacement on demand is primarily a fuel mileage thing. If memory serves, the average car needs about 40 HP to run down the road, so why feed all those extra cylinders for no gain? V V T allows for the best of both cam phasing worlds with better bottom AND top end power, courtesy of advancing/retarding the cam through the power cycle. If you're going the EFI route, why quibble about one more electronic device, especially one that'll pay you back in increased power and gas mileage? Just sayin'   :2cents:
Offline chally426
« Reply #3 on: December 19, 2014 - 09:06:20 PM »
So,...Do all 6.4's have VVT and the VVT is okay as far as putting in an older car with a 6-speed
Offline jimynick
« Reply #4 on: December 19, 2014 - 09:11:47 PM »
I don't honestly know if ALL 6.4's have V V T and I don't understand the issue about putting one in an older car with a 6 speed. None of the older cars had 6 speeds, let alone EFI or V V T or D O D, so why would it matter? Why hamstring yourself if you're going the resto-mod route by worrying about it- just do it if it makes you happy!  :cheers:
Offline chally426
« Reply #5 on: December 19, 2014 - 09:20:16 PM »
I don't care one way or another if the VVT is there, I really don't know what it does,  I just want to check if its going to cause any problems that its compatible with all the aftermarket stand alone ECM systems
Offline 7212Mopar
« Reply #6 on: December 19, 2014 - 09:32:40 PM »
The 392 crate engine does not have VVT or MDS. Not sure about the truck version. All 6.4L for Challenger, Charger and Grand Cherokee have VVT for auto and manual. Probably would not work with aftermarket ECM.
Offline jimynick
« Reply #7 on: December 19, 2014 - 10:16:46 PM »
I'd bring the subject up with some of the aftermarket suppliers and see what they say. We're right now in the middle of overhauling my son's 5.4 Ford Triton and it has V V T. The thing with that, is that if the system isn't functional, it reverts to full advance and that not only affects performance, but fuel mileage- in a significant way, and I dare say the Mopar system may have similar default parameters. It also seems to me that there was a supplier who used tweaked oem ecms and perhaps some of the more knowledgeable gentlemen here could elaborate?
Offline cjd automotive
    • The Shop
« Reply #8 on: December 22, 2014 - 06:15:09 PM »
Yes, all 6.4's have VVT.  You want it.  It allows the cam to mechanically retard and advance.  Really helps low rpm torque without affecting upper RPM horsepower.
I know the Holley controller cannot control the VVT yet.  It can be locked out with a Comp Cams kit, but if your leaving the engine relatively stock, I'd run the factory controller.
BTW, the shop truck.  VVT and MDS Hemi with factory controller.  Not pretty, but very fast!!
« Last Edit: December 22, 2014 - 06:16:54 PM by CJD AUTOMOTIVE »
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
www.STREETANDRACEPERFORMANCE.com
Jacksonville, FL 32220
904-400-1802
Offline jimynick
« Reply #9 on: December 22, 2014 - 10:46:02 PM »
That's cool, that truck is! That's also the old school hotrodding spirit as well. You can't go wrong sticking a bigger engine in it, can ya?! :thumbsup:
Offline GCCUDA
« Reply #10 on: December 30, 2014 - 09:52:18 PM »
you will need a factory pcm . no one has an aftermarket unit.  YET. and will take some time before its mastered as well .
Offline Modern Muscle
  • Moderator
    • Modern Muscle Performance Group
« Reply #11 on: January 19, 2015 - 10:27:38 AM »
All Factory 6.4L have VVT and we and our stand alone can control it in any resto mod conversion.
Offline jimynick
« Reply #12 on: January 19, 2015 - 09:56:19 PM »
There ya go! Nice to see that someone's finally managed that.  :2thumbs:
Offline teemu
« Reply #13 on: January 27, 2015 - 10:28:29 AM »
 Hi all,
 I have 6.4 Hemi in my Challenger, first I had 5.7 Hemi and aftermarket ECM, it works perfectly, but now, VVT is a problem.
 I know that I could buy original ECM, but the price, if box cost in USA $3000 when I get it,  it cost to me over $4000, I live in Finland.
 Can anybody tell, is VVT solenoid and intakesolenoid 12v or 5v, and what kind of pulse going in, only two wires going in to VVT solenoid.
  And how VVTsolenoid works. I know it works 0%, 50% and 100%, but what determines  when the solenoids open, is it RPM, pressure or what.
 Is it dangerous running the engine without VVT, if I use Comp cams locked kit, or what happen If I not lock it?
I drove this car at the last summer, and it works fine,  we keep the RPM under 3500
  Thanks, and sorry about my English
      -Teemu
Dodge Challenger convertible -70 6.4 HEMI
Plymouth superbird -70 V-code, 4-speed
Dodge Charger -70 RT/SE R-code
  • Moderator
« Reply #14 on: February 20, 2015 - 10:22:53 AM »
Hi all,
      -Teemu
VVT is controlled by the ECU.  A new ECU flased for your application is only 649.00 USD  that would be your cheapest alternative
« Last Edit: February 24, 2015 - 08:57:35 AM by Modern Muscle »
