Author Topic: Is my driveshaft modified?  (Read 3310 times)
Offline soundcontrol
« on: December 20, 2014 - 03:20:08 PM »
Hmm, took my driveshaft off today. First of all, the bolts holding the rear u-joint to the third member was long metric allen bolts(!), going thru with a nut on the end.... Then I notice a weld on my driveshaft, close to the rear u-joint, there not supposed to be welded there right? Is my driveshaft modified?
/ Ken
topic=108917.new#new
Offline roadman5312
Re: Is my driveshaft modified?
« Reply #1 on: December 20, 2014 - 03:29:17 PM »
I would say so, and metric fasteners not :nono:
« Reply #2 on: December 20, 2014 - 04:30:27 PM »
Mine doesn't look like that....
« Reply #3 on: December 20, 2014 - 08:37:02 PM »
Yep, confirmed, I got a driveshaft with a 1350 u-joint in front and a smaller 7290 rear.
I'm getting a new all 1350 driveshaft from DrDiff, I already got a new 3.55 third member, just need to change the yoke.
/ Ken
« Reply #4 on: December 20, 2014 - 09:02:38 PM »
Changing the yolk could lead to problems if it has a crush sleeve it will mess with the brg preload , if it has shims you should be OK
« Reply #5 on: December 21, 2014 - 07:24:02 AM »
I dont know much about the rear end. What is crush sleeve and brg preload? My new third member is a complete one from DrDiff. (not the one on the car now).
/ Ken
Offline 1 Wild R/T
« Reply #6 on: December 21, 2014 - 12:14:14 PM »
If Cass built it he should be able to tell you if it has a crush sleeve or not..... If it does swapping the yoke without taking the carrier out & adding a shim to increase the crush is questionable... The better approach would be to add a crush sleeve eliminator...
« Reply #7 on: December 21, 2014 - 04:21:32 PM »
Yeah, Cass built it, I'll ask him. Now I gotta read up on this so I learn something.
Few hrs later... So now I know what a crush sleeve is.
Here a video that explains it for anyone who is interested and did not know, (like me). Not a Mopar, but I'll get the function of it.
https://www.youtube.com/watch?v=mByWwsrMUMQ
« Last Edit: December 21, 2014 - 08:30:07 PM by soundcontrol »
/ Ken
« Reply #8 on: December 21, 2014 - 09:34:48 PM »
Good news for me is that Cass already put a crush sleeve eliminator in my new case, so changing the yoke should be easy.
/ Ken
Offline rUNCHARGER
« Reply #9 on: December 21, 2014 - 09:49:48 PM »
Yes: Cass is fortunately much smarter than the guy that welded that driveshaft.
Sheldon
« Reply #11 on: December 22, 2014 - 05:24:40 AM »
I'm assuming a previous owner found a suregrip third member with the smaller u-joint and just cut the driveshaft from the donor car as a quick fix.
A new driveshaft might also fix some vibrations I had, that I thought was something else. I did not see this when I bought it, even though I examined the car on a lift.
Was mostly looking for rust under though.
That tool was a smart one, I saw Rick Ehrnberg came up with it, I believe he is behind the selector support I got for the steering also.
/ Ken
« Reply #12 on: December 22, 2014 - 07:09:58 PM »
Driveshaft lenghts confuse me now, trying to measure it, to get a new one, looking at this:
http://board.moparts.org/ubbthreads/upload2/4563759-PartNoDriveshafts.pdf
Why is there 2 different 340-727-8.3/4 lenghts avaiable? And very close in lenght also...And was there a 318/727 option? with a different longer driveshaft 1970...
Hmmm. My car is a G code, don't know if it came with a 727 or a 904 originally. I measure 49" from yoke CL to end of tailhousing, then I guess driveshaft lenght is
measured center of u-joints right? If that correct, it gotta be one of the 2 shorter driveshafts.
/ Ken
