Author Topic: magnum force  (Read 2547 times)
Offline EbodyMod
  • Will it ever be finished????
magnum force
« on: December 21, 2014 - 04:54:37 PM »
 :wavingflag: Has any one used magnum forces pro-link four link suspension? looking to get it but can't find any reviews.
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline sassygreen
Re: magnum force
« Reply #1 on: December 21, 2014 - 07:34:53 PM »
Looks like a nice set up. Do you know how much it costs.
Offline EbodyMod
Re: magnum force
« Reply #2 on: December 21, 2014 - 08:58:17 PM »
 :wavingflag: It is about 2000 without powder coating and single adjustable coilovers. add 400 for coating and 300 for double adjust :working:ables
Re: magnum force
« Reply #3 on: December 21, 2014 - 09:04:56 PM »
& zero adjustment for the 4 links ???
Offline EbodyMod
Re: magnum force
« Reply #4 on: December 21, 2014 - 09:19:54 PM »
 :wavingflag: sorry the pic is bad but they are very adjustable. one of the reasons I am looking at them is I want to rasie the rear about an inch. If you do that with most of the other kits it throws the geometry off because they are designed for dropping the car
Re: magnum force
« Reply #5 on: December 21, 2014 - 10:17:34 PM »
It appears to be adjustable for ride height and pinion angle, but not for instant center locations or roll center height. With the large divergence in length between the upper and lower arms, I'm betting it produces some radical pinion angle changes as it goes through its travel.
Offline EbodyMod
Re: magnum force
« Reply #6 on: December 22, 2014 - 04:41:03 PM »
 :wavingflag: so you think it might be a mistake?
Offline 1 Wild R/T
Re: magnum force
« Reply #7 on: December 22, 2014 - 07:46:24 PM »
I realize your looking at something completely different but might want to read this thread & see how Magnum Force's customer service is before turning loose of your $$$$
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=8363988&an=0&page=0#Post8363988
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
Re: magnum force
« Reply #8 on: December 23, 2014 - 01:38:13 PM »
i have the xv rear i just installed great fit just take took my time and measured mulitple times overall was really happy with the way Chris got it all together in the time he didjust after they closed. give him a call i think its money well spent IMO. i know xv has givin a sour taste in everyones mouth but chris is really turning it around. i was so impressed i ordered the front. good luck with your decision.
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Re: magnum force
« Reply #9 on: December 23, 2014 - 05:37:26 PM »
Not necessarily, but if you're dropping that amount of coin, you will want the ability to dial in all the performance it should deliver. if you are looking at altering ride height, then you may need to adjust the system.
Offline EbodyMod
Re: magnum force
« Reply #10 on: December 23, 2014 - 05:46:47 PM »
 :wavingflag: Called Magnumforce and they ar etelling me I should have no issues with raising the back end as long as I get the pinion angle set right with all the other adjustments set so there is plenty of movment to tweak after welding the rear in. I will say I feel better after talking to them but the front suspension thread has me seriously doubting this company. that is ALOT of coin to just get a jacked up rear end.  What are you guys using that works well and can be adjusted up? :1zhelp:
