Author Topic: carburator need more performance  (Read 3707 times)
Offline cudabob496
Re: carburator need more performance
« Reply #15 on: December 27, 2014 - 07:23:21 PM »
I thank you all alot for this infomations , helps alot.
@ cudabob496 which AFR Meter Kit are you installed ? Was the installation of this kit difficult ?
Did you self made the hole for the sensor in the exhaust or did you have a header with a connection for this ?
Do install a AFR meter are a great idea which i want know mor about it .
So the Holley carburator will get cleaned and rebuilt without change the jets in the next few days, i will
look at first what the AFR meter say befor i change the jets .
I search also for headers , so i must take a look for one with connection place for the AFR .
Is it ok when the one sensor where be in a kit is installed in one header or need 2 sensors for right and left ?
this is the one I bought.
http://www.summitracing.com/parts/avm-30-4100
Its an easy install. They now have strap on bung holes, so you do not need to weld sensor fitting into the exhaust pipe.
Just drill a hole first.
only need one sensor, and I installed mine about 1.5 feet downstream of the header collector, and forward
of the X-pipe point. You can select either side to mount the sensor.
2011 Kawasaki Z1000
