Author Topic: Gasket sealer on transmission pan?  (Read 2074 times)
Offline Katfish
  • 70 Challenger
« on: May 04, 2005 - 09:04:31 AM »
I'm replacing my transmission pan, it's all beat up from getting hit by speed bumps too many times.
On the new pan, should I use a sealer on the gasket?  If so what kind?
Thanks
Offline 71fish
  • Bless you..
    • Ken's 71fish
Re: Gasket sealer on transmission pan?
« Reply #1 on: May 04, 2005 - 09:23:00 AM »
Great question. My trans pan leaks too. I replaced 3 times.. so obviously I'm doing something wrong. Step by step sped instructions would be helpful. cork gaskets are out, so which do you use. I bought the rigid gasket w/ the rubber lining.. is this one good?? If so, do I use clear silicone also??
71fish
71fish - Nobody better than an E-BODY!!
Offline Wrencher
  • 73 Plain Jane 318 Auto Project
« Reply #2 on: May 04, 2005 - 09:59:20 AM »
Auto trans gaskets should be installed with NO sealer.  Years ago, the big 3 experimented with using sealer instead of a gasket.  Works well IF everything and I mean everything is spotlessly clean with no oily residue.  So silicone was okay to use when the trans was manufactured but wouldn't work once the trans was serviced in the field.  Silicone would not stick to oily parts and would break off/fall into pan and get sucked into filter.
The pan flange needs to be flat and true.  Replace pan if necessary.  Install gasket DRY (no glue or sealer).  Use good gasket (dealer's or trans shop - not the cheapie ones folded in filter boxes) and don't overtighten.  And don't use silicone.
« Last Edit: May 04, 2005 - 10:03:22 AM by wrencher »
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #3 on: May 04, 2005 - 11:07:23 AM »
Thanks much!!    :thumbs: :thumbs: :guitar:
71fish
Offline budrinker
« Reply #4 on: May 05, 2005 - 05:16:45 AM »
i went through this for months changed the pan 20 times because of a leak well it tured out it was the shifter shaft that was leaking and not the pan at all
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #5 on: May 05, 2005 - 10:12:27 AM »
Buddrinker - pls elaborate..  :)  How does the shifter shaft leak.. & what needs to be done??
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #6 on: May 05, 2005 - 11:05:31 AM »
After our start-up a few weeks ago, we had some leaks and one of them was the trans. We changed the gasket and refilled.....still leaking.  Noticed that it was leaking out of the same spot...hmmmm.   It turned out it was the dipstick...had a bad o-ring on it.
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #7 on: May 05, 2005 - 12:54:10 PM »
Rev - I was thinking that one too, but now I'll def replace. Also going to buy a chrome pan, becasue at least I know it is perfectly FLAT..w/ a drain plug.    :ack:
71fish
Offline Robb
« Reply #8 on: May 05, 2005 - 06:38:21 PM »
IF the chrome pan with a drain plug has a 1/8" nylon gasket....   watch out.
Even though I was careful about not overtightening it...
after a year, mine cracked and started dripping profusely.
I had that, a warped original pan and a leak around the Throttle kick down after doing a shift kit install.    :banghead:
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« Reply #9 on: May 05, 2005 - 09:40:51 PM »
Hey, 71fish - I had the same problem that you have, a leak where the shifter linkage goes into the transmission. There's a pressed-in gasket there that, if not installed perfectly, will not seal correctly and you'll get that tremendously annoying leak.You need to replace that gasket, but very carefully, or you'll end up with another leak. Hope this helps!
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Offline budrinker
« Reply #10 on: May 06, 2005 - 05:23:05 AM »
a good test for a shifter seal leak is to wipe down the pan clean and dry let it sit over nite and check for leaks if you have fluid showing its the pan if not start it up drive it park it then check it for leakage if it leaks after the test drive it is most likely the ****er shaft seal
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #11 on: May 06, 2005 - 07:08:44 AM »
does antone know where I can but a 1 pc rubber / steel reinforced gasket for the 727 trans? I was told you can buy them  :dontknow:
It would be similar to the steel reinforce valve cover gaskets.. which are the best btw   :thumbs:
-71fish
Offline Katfish
  • 70 Challenger
« Reply #12 on: May 08, 2005 - 12:25:17 PM »
I got a FelPro from Advanced Auto, it's not steel reinforced, but it is rubber NOT cork.
Advanced #5785235   / FelPro #T0S18583   $6 including tax  :)
