Author Topic: heater box question  (Read 1163 times)
Offline JoeGrapes
heater box question
« on: December 26, 2014 - 05:53:04 PM »
Has anyone took A/C heater box out and put in a non A/C box? I know the firewall opening is different for the blower motor and heater hoses but does the blower motor stick thru the firewall in the same spot? Are the mounting screws for both boxes in the same spot?
Re: heater box question
« Reply #1 on: December 26, 2014 - 07:13:54 PM »
The heater box motor locations are totally different where they come out.
Offline JoeGrapes
« Reply #2 on: December 26, 2014 - 07:48:18 PM »
Thanks, I see that now. I think I'm going to have to see if I can find a piece of firewall off a non air car and replace the air cutout.
« Reply #3 on: December 26, 2014 - 09:29:32 PM »
Under the drivers side clutch pedal area is a hat for the fresh air ducting that needs to be added as well.
Offline JoeGrapes
« Reply #4 on: December 26, 2014 - 09:46:14 PM »
Yes, that I know about and I have the parts for that. Do you think you could trace the non a/c blower cutout, heater holes and mounting bolt holes on a 8 1/2 x 11 piece of paper if they will fit and send it to me maybe as a word document or something so I might make a plate from sheet metal and fit it to the firewall. No hurry, if you get a chance. Thanks.
Offline Paul97
« Reply #5 on: December 26, 2014 - 10:50:06 PM »
I have my heater box and blower out for a restoration.  Car is a 70 'cuda.  I can do this if you still need it.  Message me your e-mail.
« Reply #6 on: December 26, 2014 - 11:10:04 PM »
Can't do it. Hemi is too much in the way.
Offline JoeGrapes
« Reply #7 on: December 27, 2014 - 06:50:21 AM »
Ok topcat,  paul97 has his open and has the room to trace the opening. Thanks for the help.
Offline Paul97
« Reply #8 on: December 27, 2014 - 11:53:19 AM »
Pictures and Template on the way :thumbsup:
