Author Topic: STEERING COLUM MOUNT ?  (Read 2951 times)
Offline AZDAN
« on: December 31, 2014 - 04:15:45 PM »
Does the E body use the plastic blocks to mount the steering column to the dash bracket? Im guess not as they don slide in like the do on other columns.
Offline swede-cuda
Re: STEERING COLUM MOUNT ?
« Reply #1 on: December 31, 2014 - 04:32:02 PM »
 :wave: correct
Offline AZDAN
« Reply #2 on: December 31, 2014 - 04:54:08 PM »
Thanks for the quick answer
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #3 on: December 31, 2014 - 09:02:11 PM »
What plastic blocks?
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline jhaag
« Reply #4 on: March 19, 2015 - 09:25:54 PM »
Ok old thread, same question. These parts are listed on ebay as being used on 70-74 ebodies to mount the steering column. Are these plastic blocks/spacers actually used, and if so where? Only 2 studs and 3 blocks/spacers? confusing..  :clueless:  what say you experts?
« Last Edit: March 19, 2015 - 09:28:27 PM by jhaag »
love 70 Challengers
Offline FY1Cuda
« Reply #5 on: March 19, 2015 - 09:39:47 PM »
I just had our's all apart, and the studs are the only pieces there I recognize.
Offline jhaag
« Reply #6 on: March 20, 2015 - 04:10:10 PM »
Thanks FY1. I don't have any on mine either, but I have no idea how many times it had been apart before I got it. I see no place that it looks like they would belong. Unless someone else chimes in and says different, we can assume the ebay seller doesn't know what he is talking about.
love 70 Challengers
Offline bc3j
« Reply #7 on: March 20, 2015 - 07:09:48 PM »
I have used washers there to make an adjustment to get the steering shaft centered in the column along with moving the floor plate.  I didn't have that tool mentioned in the FSM for centering the shaft. I didn't know if there was such a thing as those spacers.  The FSM says to "shim as required."
« Last Edit: March 20, 2015 - 07:14:09 PM by bc3j »
Offline anlauto
« Reply #8 on: March 20, 2015 - 07:26:17 PM »
No plastic blocks on an E body :2cents:
« Reply #9 on: March 20, 2015 - 10:35:58 PM »
where does the black wire go and connect to?
Offline dougs bs23
« Reply #10 on: March 20, 2015 - 11:06:39 PM »
the black wire looks like maybe the horn ground,  but I've been wrong before   :hyper:
Offline anlauto
« Reply #11 on: March 21, 2015 - 08:02:10 AM »
Nowhere on an E Body :2cents:
Offline Moparparts
« Reply #12 on: March 22, 2015 - 05:15:11 PM »
No black wire or plastic spacer blocks where used on an E-Body
Offline roadman5312
« Reply #13 on: March 22, 2015 - 05:27:26 PM »
Well, Hmmmmmm. When we disassembled Toxic's Challenger there was a black wire exactly like that. I tagged and saved it for reassembly, steering column to lower dash frame. Looked like it came from the factory that way ?. The markings of the wire terminal ends looked original. Maybe a warranty horn issue.  And I believe the wire has a part # on it. I will advise. No plastic spacers.
Offline TelisSE440
« Reply #14 on: March 22, 2015 - 05:58:07 PM »
I believe the spacer's are definitely Mopar, but surely not an E-body thing. This is from Chrysler's 1968 Master Technician's Service Conference - 8 - Safe for the Road
