Author Topic: 73 Alternator bracket set up info req  (Read 2302 times)
Offline crash340
« on: January 01, 2015 - 02:51:27 AM »
Team, im looking at the alignment of my alternator with the crank and w/p drives and its a little to the rear in alignment, in the attached photo I have circled the rear upper alternator mount that has a large spring pin bush in it, shoudl it be flush with the front or back or?? and what length should the bush be that is between the alternator and the cylinder head please, does anyone have close up photo's of the original factory set up please
Greg
73 Cuda
Brisbane, Australia
Re: 73 Alternator bracket set up info req
« Reply #1 on: January 01, 2015 - 10:55:27 AM »
The rear bushing is a floater so you do not put pressure on the rear housing & crack the loop off , I think the front brackets is bent back & rear spacer is too short causing the pulley to sit too far back .
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: January 01, 2015 - 01:03:12 PM »
I had the wrong bushings like you and cracked the rear mount.
Get the right ones and fix the bracket and you will be fine.
Offline crash340
« Reply #3 on: January 01, 2015 - 05:14:58 PM »
Thanks guys, so the tube spacers should be snug up against that floating rear bush like they are in the photo correct? The front mount should be tight on the front lug, correct?
Does anyone have the correct length of the rear tube spacer that is between the head and the alternator please, I will turn one up and then deal with the front bracket
Greg
73 Cuda
Brisbane, Australia
Offline blown motor
« Reply #4 on: January 01, 2015 - 05:28:22 PM »
I put new spacers in last year and used stainless steel tube. It looks much better than painted IMO. Sorry, my car isn't here for the winter so I can't run out and measure it for you.
Offline blown motor
« Reply #5 on: January 01, 2015 - 05:37:16 PM »
Hah!! I remembered my spare parts container is here. The inside one measures 3/4" (19mm). That's on a 340. Yours looks longer. Different alternator  :clueless:  :dunno:
Offline crash340
« Reply #6 on: January 01, 2015 - 05:46:50 PM »
Thanks BM, yeah I quickly made this one up as the piece that was in there was an old steel conduit joiner, I want to turn one up and right now it is 1.250 long, the front bracket appears factory, the alternator is from a 76? mopar, it's probably only maybe at worse 1/4" out of alignment with the other pullies at worst
Greg
73 Cuda
Brisbane, Australia
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: January 02, 2015 - 02:58:52 PM »
I can tell you that the interior bushing has no gap in there. If you look at your picture at the back of the interior bushing there is a gap which will allow you to pull it closed but then snap the rear mount.
I think you need something like this:
http://www.ebay.com/itm/70-71-72-73-Barracuda-Alternator-Mounting-Bracket-Kit-/380196193713?_trksid=p2054897.l4275
Alas I have big blocks so maybe someone else can take some measurements for you.
B
Offline 734406pk
  • Andy
« Reply #8 on: January 07, 2015 - 02:04:13 AM »
Bouchelion Performance Engineering I found to be the expert in brackets and pulley arrangements. They KNOW what you need with no BS. Save time and agro and give them a call @ 843-744-6559. Good luck !
Offline crash340
« Reply #9 on: January 07, 2015 - 04:03:28 AM »
thanks guys, I turned a thick wall tube 1.230" long to go between the cyl head and the alternator sleeve, this not only spaced it correctly but being thick wall and turned, helps hold the alternator square, all looks great now thanks for your help everyone. :cheers: :2thumbs:
Greg
73 Cuda
Brisbane, Australia
« Reply #10 on: January 07, 2015 - 11:30:33 PM »
 :2thumbs:
