Author Topic: carter secondary air door open or closed at rest  (Read 1130 times)
Offline crash340
« on: January 01, 2015 - 02:58:57 AM »
guys, at rest with the engine off, no vacume etc, should the secondary air door on my TQ be closed with spring tension or hanging open??
Greg
73 Cuda
Brisbane, Australia
Offline crash340
Re: carter secondary air door open or closed at rest
« Reply #1 on: January 01, 2015 - 03:14:13 AM »
Hmmm, cracked the lock ring on the airdoor spring adjuster and it just wound round and round, no tension, pulled it out,,,,, no spring! great!!! that probably explains the WOT bog issue I have been having, the guy I bought the car from assured me he just put a kit in the carb,,,, it runs normally so well figured it was set up right..
Greg
73 Cuda
Brisbane, Australia
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #2 on: January 01, 2015 - 03:57:47 AM »
closed with slight tension....but I see you figured that out already....you need that spring for sure.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline crash340
« Reply #3 on: January 01, 2015 - 05:23:34 AM »
Yup, sure do! Now, where to get one, it looks like most carb rebuild kits don't have them, I'm in the US in a couple of weeks so I'll gran a kit then and hopefully find a spring over there some where.
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #4 on: January 01, 2015 - 05:49:49 PM »
As I'm in Australia, can someone point me in the right direction to where I can get a replacement spring and carb kit while I'm in the US without getting the run around as I will be time poor, I would order on line or phone and have it pre delivered to my hotel
Greg
73 Cuda
Brisbane, Australia
Offline moper
« Reply #5 on: January 02, 2015 - 09:08:56 AM »
I've got some spares. PM me and let me know where to send it.
Offline crash340
« Reply #6 on: January 03, 2015 - 08:07:11 PM »
PM Sent thanks Moper,
Who are the go to people for AVS Carb rebuild kits please, there are some on Ebay but whos are the best bar none, ????
Greg
73 Cuda
Brisbane, Australia
Offline Racer57
« Reply #7 on: January 03, 2015 - 10:03:13 PM »
I "think" that Eldebrock says the adjustment screw should be 1 turn tight after the door makes contact on an AVS.  Mine is 1 1/2 on a 650
Offline crash340
« Reply #8 on: January 03, 2015 - 11:03:36 PM »
Thanks Racer57,
yep, 1 1/2 turns to 2 turns does it on a Carter Thermoquad AVS, it looks like I have found a spring from a member, all I need now is a good, high quality rebuild kit for the TQ AVS from someone???? there are a few out there but hard to know which is the top shelf unit
Greg
73 Cuda
Brisbane, Australia
