I found when I made mine that there is a "sweet spot" when adjusting them. This would be where there is the least bind in the LCA bushing. Now with all stock parts one you can't adjust this, second with rubber bushings up front and the resistance they give you would never feel this "sweet spot"
When I did my front end alignment in the driveway with a caster/camber gauge and toe plates/tape measure I went to a buddys garage to double check. It was very close he didn't have to adjust much, but he did like the adjustable feature in the strut rod to bring it all together for a 4 wheel alignment. Other wise it would have taken much longer shimming the rear spring hangers etc.... but then again I was being picky and wanted to hit the numbers I wanted.
I found the rod end gave me much more suspension travel, but then again how much do you need. I'd say the adjustable feature is more important then the rod end feature. But not having both makes it had to feel the sweet spot?
