Author Topic: under hood and underneath pictures  (Read 2974 times)
Offline brotow
  • There really is a Challenger in the backround
« on: January 04, 2015 - 01:59:51 PM »
I'm in the process of assembling my '70 challenger vert and I need some picture of  the engine compartment showing routing of brake lines and wiring harness, components  mounting, horns,  and such.  Also in need of under side(bottom) pictures of brake line, fuel lines routing.
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline mrbill426
    • All Around Mopars
Re: under hood and underneath pictures
« Reply #1 on: January 04, 2015 - 03:38:42 PM »
I could use some of this too
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline brotow
« Reply #2 on: January 10, 2015 - 11:43:32 AM »
I'm looking for the routing of the brake lines under the hood and under the car and how the are attached the the car.  E brake routing I more or less have figured out.
Offline AMXguy
« Reply #3 on: January 11, 2015 - 12:44:01 PM »
You have good taste in cars.
Manual or power brakes?  maybe someone has pictures with the engine out I don't.   I could take some with the engine in but  it wouldn't be as  good.   I look at nice cars on Ebay there are some good pictures there.
If your lines aren't in good shape you might want to get a set from Fine Lines, not a lot of money and they look and fit great.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #4 on: January 11, 2015 - 02:03:44 PM »
« Reply #5 on: January 11, 2015 - 02:10:11 PM »
Offline brotow
« Reply #6 on: January 11, 2015 - 07:27:41 PM »
AMXguy , Thanks,  power brakes, all new lines.  Besides the 70 Challenger convert I'm putting together I have a 1973 AMX 401 4 spd with a custom pistol grip shifter I made, 37k original miles, 1974 Javelin 6 cyl auto 70k  almost road ready .
Offline brotow
« Reply #7 on: January 11, 2015 - 07:35:17 PM »
Topcat, thanks for the pictures. I'm slowly getting there. I more or less got the fuel, e brake and brake lines figured out. the previous "owner" put in new floors etc. no hole in the trunk for the fuel filler neck, right inner fender must be from a later year because the  holes for the '70 washer bottle are not there. I'm sure I'll find more surprises.
