Author Topic: Painting over powder coating?  (Read 558 times)
Offline AAR6BBL
« on: January 05, 2015 - 11:02:07 PM »
I mentioned this in my resto thread, but figured that it is better asked here.
Any of you experienced paint/body guys have any feedback or opinion on painting over powder coated surfaces.
The company I am considering using to blast my AAR does not prime the metal after they blast it, they powder coat and bake it.
Now I realize that this will really protect the surface well and seal it , but what about painting over the powder coating.
My paint guy has only done one vehicle that was coated this way, and says it turned out well, but doesn't have a long term track record on doing it and I don't want to throw him any curves.
 :feedback:
Greg
« Last Edit: January 05, 2015 - 11:10:33 PM by AAR6BBL »
"There's no such thing as putting a '70 AAR 'Cuda exactly where you want it. The 'Cuda isn't interested in such things, for they require finesse. Finesse asked the 'Cuda out to dinner once, but the 'Cuda stood it up to go drink beer under an overpass with her hot little sister. As far as this car is concerned, finesse can go stuff itself."
Re: Painting over powder coating?
« Reply #1 on: January 06, 2015 - 12:45:20 AM »
It'll work fine.
Only concern I would have is the tar like material betwen seams oozing out when the car is in the curing oven.
Offline dutch
« Reply #2 on: January 06, 2015 - 02:43:45 AM »
It'll work fine.
I agree.... I dont see it sealing up along every seem, and you will definalely have crap boiling out of every seam.  You could run the car through the over once before powder is applied, but still....  Also, make sure to use a powder- primer before the top coat.  I`ve seen a powdercoated car frame flake after a few years.... sure something went wrong in prepping the frame, but no matter what the cause was ... you will be very unhappy when it happens to you.  Personally I`d skip the powder and go with a good epoxy   :2cents:
Paint over powder is no problem  :2thumbs:
*** Bart ***
