Author Topic: Removal of Clock  (Read 1029 times)
Offline sbrinsky
Removal of Clock
« on: January 08, 2015 - 05:38:20 PM »
Can anyone assist me and explain how one remove factory a clock from A 1973 Cuda (Rally Cluster). Once the plastic dash bezel is removed then what?
Thanks in advance.  SB
« Last Edit: January 08, 2015 - 06:50:31 PM by sbrinsky »
Offline CHL2T
  • Handle it, man!
Re: Removal of Clock
« Reply #1 on: January 08, 2015 - 08:47:39 PM »
IIRC three 1/4 screws through the back into the housing
Offline anlauto
« Reply #2 on: January 08, 2015 - 09:09:20 PM »
You don't have to take anything off the front. Remove the radio, reach up behind and undo the three screws and it pulls out the back. :2cents:
Offline sbrinsky
« Reply #3 on: January 08, 2015 - 10:15:48 PM »
The Three screws,  are they access from the  front or  behind the clock?
I hear some people take the clock out from the front, other say from the behind, but I have to think the screws that hold the clock in place must be the three same screws whether you are coming in from the front or the back, correct?
Hoping that makes sense.
SB
Offline anlauto
« Reply #4 on: January 09, 2015 - 06:38:20 AM »
The clock WILL NOT come out the front no matter how hard you try. :2cents:
Offline sbrinsky
« Reply #5 on: January 09, 2015 - 01:38:27 PM »
Thanks Very Much all. This points me in the right direction.
